paolina_3 ®   17-Dec-2020 13:57
Welding Handbook Volume 1, 2, 3
Year: 20XX
Author: American Welding Society
Publisher: American Welding Society
Edition: 9ht
Pages count: about 2500
Description: American Welding Society is a premier professional and technical society in welding, cutting, joining, brazing, soldering, and thermal spraying. Welding Handbook, 9th edition is a work of fundamental importance in the field of welding processes. Many technical specialists provide detailed information to assist with the design and application of welding and allied processes, whatever they are.
- Welding Science and Technology, Volume 1 presents an overview of the most recent research and engineering developments of welding science and technology. Seventeen chapters cover the fundamentals of welding, cutting, joining, and allied processes.
- Volumes 2 and 3 address welding processes. Fifteen chapters of Volume 2 provide vast and comprehensive information on the arc welding and cutting processes, oxyfuel gas welding and cutting, brazing, and soldering.
- Volume 3 covers resistance, solid state, and other welding and cutting processes.
Additional info:
- Welding Handbook, Volume 1 - Welding Science and Technology, 9th edition, 985 pages
- Welding Handbook, Volume 2 - Welding Processes, Part 1, 9th edition, 788 pages
- Welding Handbook, Volume 3 - Welding Processes, Part 2, 9th edition, 728 pages
Volume 1
PREFACE
ACKNOWLEGEMENTS
CONTRIBUTORS
CHAPTER 1—SURVEY OF JOINING, CUTTING, AND ALLIED PROCESSES
CHAPTER 2—PHYSICS OF WELDING AND CUTTING
CHAPTER 3—HEAT FLOW IN WELDING
CHAPTER 4—WELDING METALLURGY
CHAPTER 5—DESIGN FOR WELDING
CHAPTER 6—TEST METHODS FOR EVALUATING WELDED JOINTS
CHAPTER 7—RESIDUAL STRESS AND DISTORTION
CHAPTER 8—SYMBOLS FOR JOINING AND INSPECTION
CHAPTER 9—WELDMENT TOOLING AND POSITIONING
CHAPTER 10—MONITORING AND CONTROL OF WELDING AND JOINING PROCESSES
CHAPTER 11—MECHANIZED, AUTOMATED, AND ROBOTIC WELDING
CHAPTER 12—ECONOMICS OF WELDING AND CUTTING
CHAPTER 13—WELD QUALITY
HAPTER 14—WELDING INSPECTION AND NONDESTRUCTIVE EXAMINATION
CHAPTER 15—QUALIFICATION AND CERTIFICATION
CHAPTER 16—CODES AND OTHER STANDARDS
CHAPTER 17—SAFE PRACTICES
APPENDIX A—TERMS AND DEFINITIONS
APPENDIX B—METRIC PRACTICE GUIDE FOR THE WELDING INDUSTRY
INDEX OF MAJOR SUBJECTS
INDEX OF NINTH EDITION
Volume 2
CHAPTER 1-ARC POWER SOURCES
CHAPTER 2-SHIELDED METAL ARC WELDING
CHAPTER 3-GAS TUNGSTEN ARC WELDING
CHAPTER 4-GAS METAL ARC WELDING
CHAPTER 5-FLUX CORED ARC WELDING
CHAPTER 6-SUBMERGED ARC WELDING
CHAPTER 7-PLASMA ARC WELDING
CHAPTER 8-ELECTROGAS WELDING
CHAPTER 9-ARC STUD WELDING
CHAPTER 10-ELECTROSLAG WELDING
CHAPTER 11-OXYFUEL GAS WELDING
CHAPTER 12-BRAZING
CHAPTER 13-SOLDERING
CHAPTER 14-OXYGEN CUTTING
CHAPTER 15-ARC CUTTING AND GOUGING
APPENDIX A-LENS SHADE SELECTOR
APPENDIX B-HEALTH AND SAFETY CODES AND OTHER STANDARDS
APPENDIX C-FILLER METAL SPECIFICATIONS
INDEX OF NINTH EDITION, Volume 2
Volume 3
CHAPTER 1—RESISTANCE SPOT AND SEAM WELDING
CHAPTER 2—PROJECTION WELDING
CHAPTER 3—FLASH AND UPSET WELDING
CHAPTER 4—RESISTANCE WELDING EQUIPMENT
CHAPTER 5—HIGH-FREQUENCY WELDING
CHAPTER 6—FRICTION WELDING
CHAPTER 7—FRICTION STIR WELDING
CHAPTER 8—ULTRASONIC WELDING
CHAPTER 9—EXPLOSION WELDING
CHAPTER 10—ADHESIVE BONDING
CHAPTER 11—THERMAL SPRAYING AND COLD SPRAYING
CHAPTER 12—DIFFUSION WELDING AND DIFFUSION BRAZING
CHAPTER 13—ELECTRON BEAM WELDING
CHAPTER 14—LASER BEAM WELDING, CUTTING AND ASSOCIATED PROCESSES
CHAPTER 15—OTHER WELDING AND CUTTING PROCESSES
APPENDIX A—AMERICAN WELDING SOCIETY SAFETY AND HEALTH STANDARDS LIST
APPENDIX B—SAFETY CODES AND OTHER STANDARDS
APPENDIX C—CONVERSIONS FOR VARIOUS PRESSURE UNITS
MAJOR SUBJECT INDEX
INDEX OF NINTH EDITION, Volume 3
Welding Handbook
Download [13 KB]
Welding inspection handbook - American Welding Society [2015, PDF]
Modern welding - Andrew D Althouse , Carl H Turnquist , Kevin E Bowditch , Mark A Bowditch [2020,…
Welding: Principles and Practices - Edward R. Bohnart [2017, PDF]
Welding Metallurgy - Volume1 - George E. Linnert [1994, PDF]
Welding Basics - 3G E-learning LLC [2024, PDF]
Advanced Joining Processes: Welding, Plastic Deformation, and Adhesion - LUCAS DA SILVA ,MOHAMAD…
Welding Engineering An Introduction - david h philips [2023, PDF]
Handbook of Welding: Processes, Control and Simulation - Francisco José Gomes da Silva [2021, PDF]
Handbook of Laser Welding Technologies - Katayama S. (ed.). [2013, PDF]
The time now is: Today 15:16
