vitbar192 ®   30-May-2025 10:31
Engineering trigonometry
Year: 1946
Author: Pease E.M.J., Wadsworth G.P.
Pages count: 493
Description: This volume is also written without presupposing any particular knowledge on the part of the student of any portion of this subject. Advanced methods are used whenever it seems advisable. But the advanced methods, as such, are so selected that they are no harder for the student to learn than the so-called elementary ones.
These advanced methods merely enable the student to compress the mathematical shorthand to the point where a problem normally containing many steps appears to contain few steps, thus permitting the student to get a clearer bird’s-eye view of the problem as a whole. Students frequently fail to complete a problem merely because the particular problem considered involves a large number of individual steps which cannot be separately appreciated until a vision of the entire process is attained. Advanced methods only will assist the student in this dilemma.
Any development of student ability to go from the physical situation to the mathematical representation, or ability to interpret the revamped equation back into new physical significance, will result in the narrowing of the present gap between the assimilation of the mathematical approaches and the applying of these approaches in succeeding courses.
Trigonometry Defined Vocabulary BuildUp
Scope of Trigonometry
Some Prerequisites to the Study of Trigonometry
Trigonometric Functions Right Triangles
Definitions and Interrelations of the Trigonometric Functions of an Angle
Numerical Values of the Trigonometric Ratios for the Special Angles 30o, 45o, 60o and Multiples of 90о
General Procedure for Solving a Right Triangle
Method of Obtaining the Trigonometric Ratios
Determination of Any Trigonometric Ratio for Any Angle
Graphical Representation of Principal Trigonometric Ratios
Engineering on Preceding Chapters
Problems From Electrical Engineering
Solution of Right Triangles in Electrical Engineering
Problems From Applied Mechanics
Problem From Surveying
Logarithms
Significance of a Logarithm
Characteristic and Mantissa of a Logarithm
Operations That May Be Simplified by Logarithms
Subtraction of a Large Logarithm from a Small Logarithm
Use of Logarithms Decimal Power
Logarithm Tables
Arrangement Functions
The Natural System of Logarithms, for Which Base = e = 2. 71828…
Arrangement and Use of Typical of Natural Logarithms
Illustrative Problems Using Common or Briggs Logarithms (Base = 10 )
Cologarithms
Illustrative Problems Involving Natural Logarithms
Change of Bases; Relation Between Common and Natural Logarithms
Stationary Adjacent Scales and Slide Rules
Use of Stationary Adjacent Scales and Slide Rules
Illustrative Problems on Construction and Use of Stationary Adjacent Scales
Use of Slide Rule for Multiplication and Division
Illustrative Problems on Construction and Use of Sliding Scales in General
Illustrative Examples on Folded and Inverted Scales
Practice in Use of K, T, and S Scales
Additional Illustrative Slide Rule Examples
Construction and Use of a Slide Rule Designed for a Particular Formula
Trigonometric Relations and Identities
Some Other Interrelations Between the Trigonometric Ratios
Identities
Formulas for sin (x÷y) and cos (x+y)
Formulas for tan (x+y) and cot (x+y)
Functions of (x —y)
Formulas for Double Angle
The “HalfAngle Formulas
Product to Sum Formulas
Sum to Product Formulas
Complex Numbers
Imaginary Numbers
Operations With Imaginary Numbers
Complex Numbers; Visualization of Imaginary Numbers
Multiplication and Division of Complex Numbers
Representation of Complex Number in Polar Coordinates
Multiplication of Complex Numbers in Polar Form
Division of Complex Numbers in Polar Form
Engineering Illustratives on Multiplication and Division of Complex Numbers
DeMoivre, s Theorem
Infinite Series for sin a and cos a
Complex Numbers and Trigonometric Functions in Terms of e
Hyperbolic Functions
Oblique Triangles
Definition of Oblique Triangle
Methods of Solving Oblique Triangles
Law of Sines
Law of Cosines
Law of Tangents
Area of Triangle in Terms of Sides by Heron’s Formula
Radius of Inscribed Circle in Terms of Sides of Triangle
Formulas for Tangents of HalfAngles in Terms of Sides
Discussion of Type IV
Solution of Triangles of Type IV
Inverse Functions
InverseFunction Notation
MultipleValuedness of an Inverse Function; Principal Values
Inverse Hyperbolic Functions
Process of Inversion Graphs
Inversion With Respect to the Unit Circle
Use of Process of Inversion in Drawing Graphs
A Circle Inverts Into a Circle
Graphical Process of Inversion for Reciprocal of a Complex Number
Engineering of Process of Inversion
Oblique Triangles Solved By Complex Numbers
Derivation of Law of Sines by Complex Numbers
Solution of Triangle of Type I (Given One Side and Two Angles) by Complex Numbers
ComplexNumber Investigation of Triangle of Type II (Given Two Sides and Included Angle)
ComplexNumber Investigation of Triangle of Type III (Given Three Sides)
ComplexNumber Investigation of Triangle of Type IV (Given Two Sides and the Angle Opposite One of Them)
Summary of Investigations of Triangles of the Four Types
Approximate Number Computations
Exact, Approximate, and Round Numbers
Significant figures
Absolute Error and Relative Error
Rounding off Numbers
Sum of Approximate Numbers
Sum of Approximate Numbers With Limit on Relative Error
Correctness of Round Numbers
Sum of Approximate Numbers That Is to Be Correct to a Particular Place
Product of an Exact Factor and an Approximate Factor That Is to Be in Error by not More Than One Unit in a Particular Place
Product of an Exact Factor and an Approximate Factor With a PreStated Limit of Relative Error
Product of Two Approximate Factors That Is to Be in Error by not More Than One Unit in a Particular Place
Additional Discussion
Product of Two Exact Factors With a PreStated Relative Error
Product of Two or More Factors With a PreStated Limit of Relative Error
Relation Among Numbers of Significant Figures in Dividend, Divisor, and Quotient
Approximations in Given Parts of Triangles
Right Spherical Triangles
Geometric Properties of General Spherical Triangle
Limiting Conditions
Classes of Right Spherical Triangles
Polar Triangle; Quadrantal Triangle
Ten Formulas and Three Theorems for Solving Right Spherical Triangles
Illustrative Problems on Solutions of Right Spherical Triangles
Terrestrial Triangles
Celestial Triangles
Oblique Spherical Triangles
Law of Sines
Law of Cosines for Sides
Law of Cosines for Angles
Classification of Spherical Triangles
Solution of Class I Triangles by Tangent HalfAngle Method
Solution of Class II Triangles by Tangent HalfSide Method
Solution of Triangles of Classes III and IV by Napier’s Analogies
How to Visualize a Spherical Triangle from Given Values
Solution of Triangles of Classes V and VI by Simultaneous Laws
Navigation
Time and Point of the Horizon at Which the Sun Rises on a Specified Date
Difference Between True Solar Time and Mean Solar Time; Equation of Time
Sidereal Time; Conversion of Greenwich Civil Time to Greenwich Sidereal Time
The “Time Sight”
Checking of Latitude
Graphical Process for Determining Latitude and Longitude
Determination of the Coordinates (Greenwich Hour Angle and Declination) of a Subsolar Point
Construction of a Mercator Chart
Dead Reckoning Position (DRP) and Sumner Line
Determination of Observer’s Latitude and Longitude Without Plotting Subcelestial Points
Appendix
Recapitulation of Formulas
Derivations of Ten Formulas For Right Spherical Triangles
Instructions For Use of Tables
Common logarithms
Natural trigonometric functions
Logarithms of trigonometric functions
Natural logarithms
Radian measure
Powers, roots, reciprocals
Powers of e and hyperbolic functions
Haversines and their logarithms
Tables
Mantissas of Common Logarithms
Natural Trigonometric Functions
Sines and Cosines
Tangents and Cotangents
Logarithmic Trigonometric Functions
Natural Logarithms
Radian Measure
Degrees to radians
Functions of angles in radians
Radians to degrees
Powers, Roots, Reciprocals
Powers of “e” and Hyperbolic Functions
Haversines
Pease E.M.J., Wadsworth G.P. Engineering trigonometry, 1946.pdf
Download [5 KB]
The Principles and Practice of Navigation - A. Frost [1997, PDF]
Navigation Calulators HTML [2022]
Machinery’s Handbook (29th Edition) - Erik Oberg, Franklin D. Jones [2009, PDF]
Practical Advanced Navigation - Charles H. Cugle [1922, PDF]
A Short Guide to Celestial Navigation - Henning Umland [2001, PDF]
Astronavigation: A Method for Determining Exact Position by the Stars - Kurt Anton Zischka [2017,…
Burdwood’s Tables Second Edition (DAVIS. 2) - Sun’s True Bearing or Azimuth Tables - Percy L. H.…
eCalc (Scientific Calculator) v.1.5.1 [2009]
A Short Course on Nautical Charts and Basic Plotting - Gary C. Kessler [2017, PDF]
The time now is: Today 17:15
