pakasi ®   17-Mar-2022 03:12
Fire Alarm System - Diagrams
Year: 2014
Author: Cornel Barbu
Genre: Reference book
Publisher: Cornel Barbu
ISBN: B007WFHZX6
Pages count: 191
Description: Sometime one picture is more than 1000 words !
This book is dedicated those young electricians working hard to build their career.You'll learn looking and understanding the specific sketches and diagrams for this section of the electrical field -The Fire Alarm System.
You visual memory will capture the drawings, pictures, sketches and will provide you an interesting data base of information available where and when you need it.
I create all these drawings and diagrams in order to easy explain the facts in electrical trade and I realize that they are enough…. they tell us everything we looking for and no words are necessary.
It is very practical and efficient method of learning.
If need words and pictures please see the reference book (Electrician's Book-Fire Alarm System)
FIRE ALARM SYSTEM-Sketches & Diagrams 2
Copyright 3
Table Of Contents 4
Dedication 8
Ground floor room lay-out 9
Ground floor room schedule 10
First floor room lay-out 11
First floor room schedule 12
Basement room lay-out 13
Basement room schedule 14
Class B wiring for fire alarm 15
EOL (end of line resistor) 17
Class A wiring for fire alarm 18
Class A wiring for fire alarm 20
Fire Alarm Control Panel 22
FACP’s Display 25
Annunciation Panel 26
FACP System normal 27
FACP will provide “in time” information 29
FACP & ANN Panel 31
Manual pull station 33
Initiation Circuit class B 35
Initiation Circuit class A 37
Class A Diagram 39
Notification circuit Class A 40
Cables and wires for FAS(fire alarm system) 41Restrictions in power supply for FACP 42
The power supply for FACP 44
Symbols for devices required in fire alarm system 46
Devices on the loop 48
Smoke Detector 49
Physical description Smoke Detector 50
Manual Pull Station and Smoke detectors 52
Manual pull station on the loop 54
How the manual pull station 55
looks like 55
The glass rod 56
Access door devices 57
Special modules to monitor, supervise and/or control the
equipment,devices 59
Addressable devices 61
Smoke Duct Detector 62
HVAC System & Fire Alarm System 64
Smoke Duct detector installation 66
Smoke Duct detector front view 67
RTU & AHU what is this for? 68
Sprinkler system –Supervised valve 69
Valve interfaces with FAS 71
Details Valve-JB-EOL 73
Module, Valve control box and EOL resistor 74
Valve supervision and EOL resistor location 76
Intelligent module for Valve supervision on the loop 78
Single gang box for EOL 80
Details for you to install the JB for EOL 82
Details for you to install the JB for supervising module 84Similar modules to connect Flow Switches on the fire alarm system
86
How the module is connected to the loop 88
SIGA CT2 90
More about SIGA –CT1/CT2 92
The Flow Switch 94
Where the FS is on the loop 96
Isolator Module (IM) 98
Isolator module SIGA-IM details for stairways 100
Typical details for installation IM on the stairways 102
The purpose of IM 104
IM how it looks like 106
The right JB for IM installation on field 108
Detectors for Elevator’s control 110
Control Relay 112
Proper JB for the control relay 114
Devices for access control doors 116
Magnetic Lock 118
Door Holder 119
Door holder’s installation 121
Door holder ON 124
Door holder OFF 126
Automatic Transfer Switch and Fire alarm system interconnections
128
Notification of the fire event 130
Horne and Strobes for notifications 132
NAC Circuits 134
How the horn & strobes look like? 136
How to terminate the wires to the horn or strobe (NAC devices) 138
Combination device Horn & Strobe 140How to terminate the wires to the combination horn & strobe device
142
Fire alarm strobe 144
Wiring termination to the Strobe device 146
How to terminate the wires to the combination horn & strobe devices with
the synchronization module 148
Simple diagram for FACP 150
Isolation Module on NAC circuit 152
Isolation Module (IM) - SCISM 154
Class A- NAC circuits & Isolator Module 156
Class B- NAC circuits & Isolator Module 158
NAC with IM & Silence Switch 160
NAC with IM with out Silence Switch 162
Electrical Wiring Diagram (EWD) for NAC circuits 164
Inside room silence switch 166
Conduit, devices, wiring & lay-out for Initiation circuit 168
Conduit, devices ,wiring & lay-out NAC 170
NAC1 –Conduit Lay-out 172
NAC2 –Conduit Lay-out 174
Block Diagram Fire Alarm System 176
Conduit for FAS –Details 178
Fittings& Conduits for FAS –Details 180
Fittings& Conduits for FAS –More Details 182
Connectors –More Details 184
Wiring protection 186
Horn & Strobe combination device –surface installation 188
Example of work preparation for FAS installation: Conduit ,Boxes, devices,
wiring 190
Example of work preparation for FAS installation 192
About The Author 194
FA System.pdf
Судовая станция пожарной сигнализации - Autronica / Fire Alarm Sistem BS-100/2 Samsung/1139 [1995,…
Foundation Course For Electrical Drafter - 3G E-Learning [2021, PDF]
Electrical Engineer’s Portable Handbook - Robert B. Hickey, P.E. [2004, PDF]
UGLY’S Electrical References - George V. Hart [2014, PDF]
UGLY’S ELECTRICAL REFERENCES - George V. Hart [2005, PDF]
The time now is: Today 16:08
