virtual ®   26-Apr-2020 13:23
Furuno Operator's manual navigational Echo Sounder Model FE-800
Year: 2014
Author: Furuno
Pages count: 48
Description: The FE-800 is a color navigation echo sounder which operates with 50 or 200 kHz frequency. The FE-800 is comprised of a control unit, transceiver, matching box and transducer. Echoes are output on an 8.4-inch LCD screen.
The main features of the FE-800 are:
• Complies with the following regulations: ISO9875:2000, IEC60945 Ed.4, IEC61162-1 Ed.4, IEC61162-1 450, IEC62288 Ed.2.
• Can display dual frequency (50 kHz/200 Khz) depth reading on one screen.
• Three display modes available:
• NAV mode: Standard display showing depth readings.
• OS DATA mode: Shows own ship location, time, COG/SOG alongside current depth readings.
• HISTORY mode: Shows past readings in graph form alongside current depth readings.
• Can be connected to an external monitor (RD-20/RD-50) for remote display of readings.
• Compatible with Bridge Alert Management systems - IMO MSC.302(87)
• Can connect up to two transceivers, allowing dual on-screen display of echoes.
• Connecting the optional printer allows printing of echo data.
• Can save/replay up to 24 hours of depth reading history.
• Connecting a PC with the optional data recording software allows recording of echo data.
FE-800-2.pdf
Download [6 KB]
Furuno Felcom 18 Inmarsat-C Operators Manual - Furuno [2012, PDF]
Furuno Class A AIS Operators Manual + Guide FA-170 - [2015, PDF]
Furuno Operator’s Manual Live Player V5, Model VR-7030 - Furuno [2014, PDF]
Furuno Color Instrument FI-70 Operators Manual - Furuno [2016, PDF]
Furuno Operator’s Manual Satellite Compass Model SC-70, SC-130 - Furuno [2020, PDF]
The time now is: Today 13:21
