Arcan ®   18-Feb-2018 14:22
JRC NAVTEX Receiver Instruction Manual NCR-333
Year: 2013
Author: JRC
Publisher: JRC
Edition: 4
Pages count: 120
Description: The NAVTEX NCR-333 function receives and displays the various types of information broadcast
at frequencies of 518 kHz, 490 kHz and 4209.5 kHz, such as: navigational warning,
meteorological warning, search and rescue information, and other types of information. NCR-333
also provides the function that selects information type and coast station for intended uses.
Features
● Receiving NAVTEX broadcasts
NCR-333 receives NAVTEX broadcasts automatically on 518 kHz, 490 kHz, and 4209.5 kHz.
● Large screen allows comfortable visibility
NCR-333 has a 5.7-inch LCD screen display with clear visibility.
It also provides three different character sizes of display, and can be selected at your
convenience.
● Message saving function
NCR-333 can store up to 200 message identification codes for 70 hours. Moreover, the stored
message of each channel can be saved up to 50 messages permanently.
● Automatically receiving station setting function
NCR-333 can select receiving stations automatically on GPS position data is valid.
● Permanent storage of data settings
NCR-333 can set and store the message type and seashore station that receive to internal
memory. The data, therefore, does not need to be re-set, even after power has been turned off.
● Dual voltage supply input
NCR-333 can be used on wither 24 VDC or 12 VDC vessels.
● Self-diagnosis Function
NCR-333 has automatic self-diagnosis function. This function allows easy maintenance and high
system reliability.
● Connection to external equipment
NCR-333 can be used with the JRC Total Navigator (ECDIS) and external serial printers.
JRC NAVTEX Receiver NCR-333
Download [4 KB]
Furuno NAVTEX Receiver NX-700A/B Operators Manual - Furuno [2015, PDF]
Furuno Operator’s Manual Navtex Receiver NX-700A/B - Furuno [2006, PDF]
Samyung SNX-300 NAVTEX Receiver User Manual - Samyung ENC [2006, PDF]
Thrane & Thrane - Sailor-6390 Navtex Receiver Installation and User manuals - Thrane & Thrane A/S…
International SafetyNET Services Manual - IMO [2022, PDF]
Mc Murdo Smartfind GMDSS Navtex, GMDSS Tri-Channel Navtex Receiver User & Installation Manual,…
Furuno AIS Receiver Operators Manual FA-50 - [2016, PDF]
Samyung SFAX-500 weather fax receiver User Manual - Samyung ENC [2016, PDF]
JRC GPS Navigator Instruction Manual JLR-7500-7800 - JRC [2009, PDF]
NAVTEX Manual - IMO [2018, PDF]
The time now is: Today 14:22
