janataly ®   20-Feb-2013 17:02
Guidance for the Prevention of Roll over on LNG Ships
Year: 2012
Author: SIGTTO
Genre: Handbook
Publisher: Witherby Publishing Group Ltd
Series: First Edition
ISBN: 978-1-85609-558-7
Number of pages: 14
Description: "Rollover" refers to the rapid release of LNG vapour
that can occur as a result of the spontaneous mixing
of layers of different densities of LNG in a storage
or cargo tank. A pre-condition for rollover is that
stratification has occurred, ie the existence in the tank
of two separate layers of LNG of different density.
The possibility of a sudden release of large amounts
of vapour and the potential over-pressurisation of
the tank resulting in possible damage or failure is
recognised by the major design codes. EN 1473 -
"The design of onshore LNG terminals" and NFPA
59A - "Standard for the Production, Storage and
Handling of LNG" both require this phenomenon to
be taken into consideration when sizing relief devices.
Whilst the relief valves may prevent damage to the
tank, LNG vapour is not only flammable and heavier
than air on release, but a valuable commodity and a
potent greenhouse gas and therefore venting should
be avoided whenever possible.
Gas rollover.pdf
Download [16 KB]
Guidance for the Prevention of Rollover in LNG Ships - SIGTTO [2012, PDF]
LNG Transfer Arms and Manifold Draining, Purging and Disconnection Procedure - SIGTTO [2012, PDF]
Rollover Prevention: A Review of Causes, Methods for Prevention and Damage Limitation Measures - SIG...
A Guide To Contingency Planning For Marine Terminals Handling Liquefied Gases In Bulk - SIGTTO [2001...
Guidelines for the Alleviation of Excessive Surge Pressures on ESD - SIGTTO [1987, PDF]
Ship Vetting and its Application to LNG - SIGTTO [2004, PDF]
The Selection and Testing of Valves for LPG Applications - SIGTTO [2012, PDF]
The Selection and Testing of Valves for LNG Applications - SIGTTO [2008, PDF]
Guidelines for Automatic Cargo Tank Overfill Protection Aboard Gas Carriers - SIGTTO [1993, PDF]
ESD Arrangements & linked ship shore systems for Liquefied Gas Carriers - SIGTTO [2009, PDF]
The time now is: Today 13:57
