namemamun ®   16-Dec-2023 20:46
Pressure Relief Valve Engineering Handbook
Year: 2012
Author: Anderson Greenwood
Genre: Handbook
Publisher: Emerson
Pages count: 232
Description: The primary purpose of a pressure or vacuum relief valve is to protect
life and property by venting process fluid from an over pressurized vessel
or adding fluid (such as air) to prevent formation of a vacuum strong
enough to cause a storage tank to collapse.
Proper sizing, selection, manufacture, assembly, testing, installation,
and maintenance of a pressure relief valve are all critical for optimal
protection of the vessel or system.
Please note that the brand names of pressure relief devices covered
(Anderson Greenwood, Crosby, Whessoe and Varec) are of Emerson
manufacture. A specific valve brand is selected, according to pressure
range, temperature range, valve size, industry application and other
applicable factors.
This manual has been designed to provide a service to Emerson
customers by presenting reference data and technical recommendations
based on over 125 years of pioneering research, development, design,
manufacture and application of pressure relief valves. Sufficient data
is supplied so that an individual will be able to use this manual as an
effective aid to properly size and select Emerson-manufactured pressure
relief devices for specific applications. Information covering terminology,
standards, codes, basic design, sizing and selection are presented in an
easy to use format.
Pressure-relief-valve-engineering-handbook.pdf
The Safety Relief Valve Handbook - Marc Hellemans [2009, PDF]
The Selection and Testing of Valves for LPG Applications - SIGTTO [2012, PDF]
Valve Selection In Piping Systems For Oil And Gas [2024, MP4]
Recommendations For Relief Valves On Gas Carriers - SIGTTO [2020, PDF]
The Selection and Testing of Valves for LNG Applications - SIGTTO [2008, PDF]
Valve Handbook - P.Skousen [2011, PDF]
Control Valve Handbook - Emerson Process Management [2005, PDF]
Recommendations for Relief Valves on Gas Carriers - SIGTTO [2020, PDF]
Control Valve Maintenance and Troubleshooting [2023, MP4]
Compressors Selection and Sizing - Royce N. Brown [1997, PDF]
The time now is: Today 15:14
