Romate ®   30-Oct-2025 19:55
ISO 12215:2-2018 / Small craft – Hull construction and scantlings Part 2: Materials: Core materials for sandwich construction, embedded materials
Author: ISO
Genre: Нормативный документ
Publisher: ISO
Edition: 2nd edition
Number of pages: 14
Description: Attention is drawn to the possibility that some of the elements of this part of ISO 12215 may be the subject of patent rights. ISO shall not be held responsible for identifying any or all such patent rights.
ISO 12215-2 was prepared by Technical Committee ISO/TC 188, Small craft.
This part of ISO 12215 specifies requirements for core materials for structural use and materials that are embedded
in sandwich construction. It is applicable to small craft with a hull length (LH) according to ISO 8666 of up to 24 m.
NOTE The underlying reason for preparing this part of ISO 12215 is that sandwich structures of small craft require careful
selection of core materials from a multitude of choices, and that the manufacturing has to follow certain procedures to achieve
the intended long-term durability under the expected loads and environmental conditions.
Additional info: ISO 12215 consists of the following parts, under the general title Small craft — Hull construction and scantlings:
 Part 1: Materials: Thermosetting resins, glass-fibre reinforcement, reference laminate
 Part 2: Materials: Core materials for sandwich construction, embedded materials
 Part 3: Materials: Steel, aluminium alloys, wood, other materials
 Part 4: Workshop and manufacturing
 Part 5: Design pressures, design stresses, scantling determination
 Part 6: Structural arrangements and details
Annex A forms a normative part of this part of ISO 12215.
BS_EN_ISO_12215_2_2018.pdf
Download [1 KB]
ISO 12215-1:2018 / Small craft – Hull construction and scantlings Part 1: Materials: Thermosetting…
ISO 12215-5 / Small craft — Hull construction and scantlings — Part 5: Design pressures for…
ISO 12215:10-2020 / Small craft — Hull construction and scantlings — Part 10: Rig loads and rig…
Ships and marine technology — Pilot ladders — Part 3: Attachments and associated equipment - ISO…
BV - Rules for the Classification of Steel Ships - PART B – Hull and Stability -2021 - BUREAU…
Aluminum Structure Design and Fabrication Guide: Aluminum Structure, Marine Structure, Aluminum…
Survey of Structural Tolerances in the United States Commercial Shipbuilding Industry - Ship…
Ships and marine technology — Pilot ladders — Part 2: Maintenance, use, survey, and inspection -…
Marine applications of advanced fibre-reinforced composites - Graham-Jones J., Summerscales J.…
ISO-12215-7-2020 - ISO [2020, PDF]
The time now is: Today 16:08
