Romate ®   30-Oct-2025 16:24
ISO 12215-5 / Small craft — Hull construction and scantlings — Part 5: Design pressures for monohulls, design stresses, scantlings determination
Year: 2024
Author: ISO
Genre: Нормативный документ
Publisher: ISO
Edition: 2nd edition / Corrected version
Number of pages: 136
Description: The committee responsible for this document is ISO/TC 188, Small craft.
This second edition cancels and replaces the first edition (ISO 12215-5:2008, including its amendment ISO 12215-5:2008/Amd 1:2014), which has been technically revised.
One of the main reasons to achieve this revision, after a decade implementing the first edition, was to allow other scantlings calculation methods than those given in the 2008 edition, noting the huge development of finite element analysis methods and software, and the trend already applied in ISO 12215-9 (keels and appendages) and ISO 12215-7 (multihulls).
Therefore, in this new edition, like in many other scantlings standards, the design pressure loads, and the design stresses are given in the main body of the standard and, where needed, the scantlings calculation methods are detailed in Annexes.
The main changes compared to the previous edition are as follows:
— clarification of the scope and of many definitions, dimensions, and assessment;
— definition of a theoretical hull/deck limit height ZSDT in Table 3;
— renaming of nGC into kDYN in Table 7;
— lowering of the values of kL in the aft part of the craft in Table 8;
— deletion of kAR min, to better consider large panels, mainly sandwiches, in Table 9;
— improvement of the values of kSUP in Table 10;
— modification of design pressures for motor and sailing craft in Tables 12 & 13;
— modification of design stresses introducing kBB and kAM factors in Tables 15 to 17;
— incorporation of requirements for work boats in Table 2, Clause 12 and Annex J;
— possibility to use a wider range of assessment methods detailed in Table 18;
— move of the previous assessment method (now called "simplified") in Annex A;
Additional info: This document defines the dimensions, design local pressures, mechanical properties and design stresses for the scantlings determination of monohull small craft with a hull length (LH) or a load line length (see NOTE 1) of up to 24 m. It considers all parts of the craft that are assumed to be watertight or weathertight when assessing stability, freeboard and buoyancy in accordance with ISO 12217.
ISO 12215-5-2019 (2024).pdf
Download [9 KB]
ISO 12215:2-2018 / Small craft – Hull construction and scantlings Part 2: Materials: Core materials ...
ISO 12215-1:2018 / Small craft – Hull construction and scantlings Part 1: Materials: Thermosetting r...
ISO 12215:10-2020 / Small craft — Hull construction and scantlings — Part 10: Rig loads and rig atta...
Ships and marine technology — Pilot ladders — Part 2: Maintenance, use, survey, and inspection - ISO...
Ships and marine technology — Pilot ladders — Part 3: Attachments and associated equipment - ISO [20...
Survey of Structural Tolerances in the United States Commercial Shipbuilding Industry - Ship Structu...
Watchkeeping Safety – Use of VHF Radio and AIS - MGN 324 (M+F), Amendment 1 - MCA [2017, PDF]
Safety of Ro-Ro Passenger & Cruise Ships, January 2018 NI 388 - REVISION 12 - BV [2018, PDF]
The time now is: Today 12:09
