Romate ®   31-Oct-2025 13:29
ISO 12215:10-2020 / Small craft — Hull construction and scantlings — Part 10: Rig loads and rig attachment in sailing craft
Year: 2020
Author: ISO
Genre: Нормативный документ
Publisher: ISO
Edition: 1st edition
Number of pages: 86
Description: The reason underlying the preparation of the ISO 12215 series is that scantlings rules and recommended practices for small craft differ considerably, thus limiting the general worldwide acceptability of craft.
This document has been set towards the minimal requirements of the current practice.
The dimensioning according to this document is regarded as reflecting current practice, provided the craft is correctly handled in the sense of good seamanship and equipped and operated at a speed appropriate to the prevailing sea state.
This document is not a design standard, and designers/builders are strongly cautioned from attempting to design craft such that nearly all structural components only just comply.
The connection between the rig attachment and the structure is required to be stronger than the rig attachment itself. It is therefore considered that unforeseen overload will not entail its detachment from the structure, and that the watertight integrity will be maintained.
Additional info: This document was prepared by ISO/TC 188, Small craft.
A list of all parts in the ISO 12215 series can be found on the ISO website.
ISO 12215-10-2020.pdf
ISO 12215:2-2018 / Small craft – Hull construction and scantlings Part 2: Materials: Core materials…
Ships and marine technology — Pilot ladders — Part 2: Maintenance, use, survey, and inspection -…
ISO 12215-1:2018 / Small craft – Hull construction and scantlings Part 1: Materials: Thermosetting…
Ships and marine technology — Pilot ladders — Part 3: Attachments and associated equipment - ISO…
ISO 12215-5 / Small craft — Hull construction and scantlings — Part 5: Design pressures for…
ISO-12215-7-2020 - ISO [2020, PDF]
BV - Rules for the Classification of Steel Ships - PART B – Hull and Stability -2021 - BUREAU…
Rules for Classification and Construction - Germanischer Lloyd [2003, PDF]
Rules for Classification and Construction I - Ship Technology - Germanischer Lloyd [2013, PDF]
Determination of structural capacity by non-linear finite element analysis methods DNVGL-RP-C208 -…
The time now is: Today 16:09
