zxc ®   29-Nov-2012 18:07
LIEBHERR Cargo deck crane CBW 40 / 29,5 ST / INSTRUCTION AND MAINTENANCE MANUAL + TECHNICAL INFORMATION
Year: 2000
Author: LIEBHERR
Genre: INSTRUCTION MANUAL
Series: 29.08.2000 / ab
Quality: OCR without errors
Number of pages: 321
Description: CARGO DECK CRANE CBW 40 / 29,5 ST
- VOLUME 1 – INSTRUCTION / MAINTENANCE MANUAL
- VOLUME 2 – TECHNICAL INFORMATION
- VOLUME 3 – SPARE PARTS LIST
The DOCUMENTATION is prepared for extended service, repair and maintenance work as well as ordering spare parts. This manual shall be used by trained Service personnel only.
This LIEBHERR crane shall be operated and serviced by from LIEBHERR-WERK NENZING trained or authorized personnel only.
The procedures described in the DOCUMENTATION and general safety precautions shall be observed at all times.
[color]NON-OBSERVANCE OF THESE RULES CAN RESULT IN PERSONAL INJURY AND STRUCTURAL DAMAGE.
Special attention shall be given to the safety devices built-in to the crane. They shall be tested at regular intervals for good condition and proper operation. Crane operation is prohibited if the safety devices are not working properly.
[color]"SAFETY ALWAYS COMES FIRST" must be the way of thinking and behaviour before, during and after crane operation.
If you receive any further information for the crane, such as technical modifications or changes concerning operation, maintenance, or spare parts – please attach them to provided volumes.
The LIEBHERR CARGO DECK CRANE is designed only for crane operation and only lifting appliances which have been approved by the crane manufacturer are to be used. The crane may only be used for loads which lie within the limits of the appropriate load curve.
It is to be assumed that the exterior conditions for the working range of the crane do meet the working requirements, so that the technical details stated in the section 'Technical Data' regarding angles, inclines, etc. can be maintained without risk.
When working, the crane is designed for hook operation. This also applies when the corresponding hoist accessories used by the customer meet the regulations of the crane type. In case of any doubts, this should be explicitly clarified.
Use of professional personnel
Operation, service, maintenance and repairs may only be carried out by specially trained personnel. It must be ensured that the trained personnel who are engaged do not only dispose of the corresponding specialized knowledge, but in addition also know and use all questions relating to safety and prevention of accident regulations.
Environmental Conditions
For the safe operation of the crane it is absolutely necessary to ensure that the environmental conditions, under which the machine will be operating, are according to regulations.
This machine is used primarily for hoisting, lowering and positioning of loads. To operate with maximum safety certain procedures must be followed.
One capacity chart label (load diagram) is supplied with this crane. It is placed in the driver's cabin. The load diagram shows the max. permissible load which is allowed to be lifted in correspondence to the actual radius. The actual load and radius for main- or whip hoist are indicated on two displays in the cabin.
INDEX – VOLUME 1
1. PREFACE . . . . . 1.5
1.1. TO THE OWNER . . . . . . . . . . . 1.5
1.2. GENERAL INFORMATION . . . 1.6
1.3. CRANE APPLICATION AND OPERATION . 1.6
1.4. CONVERSION TABLE . . . . . . 1.8
1.5. STANDARD HAND SIGNALS FOR CONTROLLING CRANE OPERATIONS . 1.9
1.6. GENERAL HINTS AND ADVISE FOR CRANE OPERATION . . . . . . . . . . 1.10
1.7. EXPLANATION OF SAFETY SIGNS . . . . . . . 1.15
1.8. LIEBHERR WORLD-WIDE SERVICE ORGANIZATION . . 1.19
2. GENERAL DESCRIPTION . . 2.3
2.1. ARRANGEMENT OF CRANES ON SHIP . . 2.3
2.2. ARRANGEMENT OF THE MAIN PARTS OF THE CRANE 2.4
2.3. TECHNICAL DESCRIPTION OF THE LIEBHERR DECK CRANE . . . . . . 2.9
2.4. LAYOUT OF THE OPERATOR'S CABIN . . . 2.13
2.5. CONTROLS ON THE SWITCH CABINET X1 . . . . . . . . . . . 2.19
2.6. PREPARATIONS FOR CRANE OPERATION . . . . . . . . . . . 2.20
2.7. ADDITIONAL CRANE OPERATION . . . . . . . 2.22
3. MAINTENANCE . . . . . . . . . . . 3.3
3.1. GENERAL . . . . . 3.3
3.2. SPECIAL SAFETY REGULATIONS . . . . . . . . 3.4
3.3. MAINTENANCE OF HYDRAULIC SYSTEM 3.11
3.4. PRESSURE ACCUMULATORS . . . . . . . . . . . 3.15
3.5. LIEBHERR CONDITION MONITORING . . . 3.16
3.6. GEARBOXES . . 3.21
3.7. MULTIPLE DISC BRAKES . . . 3.25
3.8. INSTRUCTIONS FOR USE OF CRANE ROPES . . . . . . . . 3.26
3.9. REPLACEMENT OF ROPES . 3.30
3.10. ROPE PULLEYS . . . . . . . . . . . 3.34
3.11. ROLLER SLEWING RING . . . 3.37
3.12. ELECTRICAL SYSTEM . . . . . . 3.38
3.13. MAINTENANCE INSTRUCTIONS FOR SLIP RING UNIT . 3.39
3.14. LUBRICATION AND GREASING DIAGRAM 3.40
3.15. MAINTENANCE LISTS . . . . . 3.41
3.16. SERVICE SPARE-PARTS AND STANDARD TOOLS . . . . 3.59
TABLE OF LUBRICANTS
INDEX – VOLUME 2
4. TECHNICAL DESCRIPTION . . . . . . . . . . 4.5
4.1. TECHNICAL DATA . . . . . . 4.5
4.2. TECHNICAL DESCRIPTION – ELECTRIC . . . . . . . . . . . . 4.7
5. DESCRIPTION OF HYDRAULIC FUNCTIONS . . . . . . . 5.3
5.1. GENERAL . . 5.3
5.2. DESCRIPTION OF THE MAIN HYDRAULIC COMPONENTS . . . . . . . . . 5.4
5.3. EXPLANATION OF HYDRAULIC CONTROL SYSTEM . . 5.13
5.4. HOIST MOTION . . . . . . . . 5.15
5.5. SLEW MOTION . . . . . . . . . 5.15
5.6. JIB MOTION . . . . . . . . . . . . 5.16
5.7. OIL COOLER CIRCUIT . . . 5.16
5.8. OIL PRESSURE TABLE . . 5.17
6. EMERGENCY OPERATIONS . . . . . . . . . 6.3
6.1. INSTRUCTIONS FOR EMERGENCY HAND PUMP (only at main motor standstill) . . . . . . . . . 6.3
6.2. PROCEDURE TO LOWER THE LOAD FOR HOISTING GEAR . . . . . . 6.4
6.3. PROCEDURE TO LOWER THE JIB . . . . . 6.5
6.4. PROCEDURE TO RELEASE THE SLEWING BRAKES . . 6.7
7. DRAWINGS
ELECTRIC / ELECTRONIC 979/2 –4.2– / –4.3– 979/2
Note: This manual is intended for trained service personnel only.
LIEBHERR CARGO DECK CRANE TYPE CBW 40 - 29,5 ST
Download [17 KB]
Astart   04-Nov-2013 14:46
how can i download this? tanx
Sign up and download what u want.
doanphuonganh2002   26-Jun-2015 02:28
Dear Sir,
OUR COMPANY RECEIVED VERY HAPPY IF YOUR ANSWERS TK SHIP.
THIS COMPANY WE WOULD REQUEST response YOUR COMPANY AS FOLLOWS:
1. COMPANY FULL NAME WE HAVE BEEN REGISTERED WITH GOVERNMENT OF VIETNAM IS: Hoang Ngoc Phuong CORPORATION, AGENTS ONLY IN 18/43 PHAM NGOC St, Tan Quy Ward, Tan Phu-.HCM City.Viet nam.
Our company is a commercial company, specialized in providing construction equipment and ports .We are received 01 orders From Port HCM Port,for the model is the Used LiebherrDeck crane type 40/38 CBW production unloading of maker: LIEBHERR used, good quality active # 70 -> 80% 40-38 .This Deck crane type CBW Deck crane 40/38 will be installed stand (shown attached) at the port in the Ho Chi Minh city so we recommended Viet Nam.
So, quarterly company conference offered include shipping ( CIF )cost-installation-guidance .... The installation operation CBW ground Deck crane at the Port of cement we can use your help customers noted, capacity this deck crane to reach 40 tons for cargo and container handling.
We wish you a company early and quote responses for our company.
Best Regards,
Dinh Cong Doan (Mr. Đoàn)
Director of Hoang Ngoc Phuong Corp.
286/23 To Hien Thanh St., Ward. 15, District 10, HCMC, Vietnam
Tel: +84 38 621 196 Fax: +84 62 934 247
Phone: +84 903 807 757 / +84 917 164 957
Email: [email protected]
Hydraulic Crane PK xxx M , PK x80 M (Operators Manual) - Crane Power [2005, PDF]
The time now is: Today 15:04
