zxc ®   07-Oct-2012 21:07
Adjustment Procedure for MG-800 Governor System and MacGREGOR Hydraulic
Year: 2005
Author: NABCO
Genre: MANUAL
Publisher: MacGREGOR, NABCO, MAN-B&W
Format: JPG,TIFF
Number of pages: 79
Description: MAN-B&W/MCG-301/EAR-500&1000
Starting-up, Manoeuvring and Arrival in Port
The following descriptions cover the standard manoeuvring system for the 50-98MC engines.
Since the manoeuvring system supplied for a specific engine may differ from the standard system, Chapter 907 in Volume III and ‘Plant Installation Drawings' should always be consulted when dealing with questions regarding a specific plant.
1. Preparations for Starting
See Chapter 705, Item 3.3 regarding correct fuel oil temperature before starting.
Regarding checks to be made before starting, when cylinders are out of operation, see Chapter 704, ‘Emergency Running with Cylinders or Turbochargers out of Operation’, Item
MacGREGOR Hydraulic Function
The following description refers to the standard hydraulic system of MacGREGOR hydraulic deck cranes, normal version.
Minor variations in the hydraulic system may occur in individual cranes of the same type, and the objective of this description is only to provide a general orientation concerning the arrangement of the hydraulic system.
Acomplete hydraulic circuit diagram relating specifically to your crane will be found in the instruction manual, section “Spare Parts", Group 9.4.
Three separate hydraulic work circuits, ie, the hoisting, luffing, and slewing circuits, plus feed and control-pressure circuits, make up the complete crane
operating system.
Each of these work circuits may have one or more pumps located in the pump unit, in Figure 1 marked PHO, PLU, PSL. Pump PF for the feed and control-pressure system is located inside the hydraulic reservoir.
1... Hoisting circuit
2... Luffing circuit
3... Slewing circuit
4... Feed and control-pressure circuit
5... Additional programming equipment *)
6... Twin crane hydraulic equipment
7... Other additional hydraulic equipment *)
#) Equipment installed at request of customer
Hydraulic motor, hoisting circuit Hydraulic motor, luffing circuit Hydraulic motor, slewing circuit Pump, hoisting circuit Pump, luffing circuit Pump, slewing circuit Pump, feed circuit
Identifying circuits in the hydraulic diagram
Figure 1 shows the arrangement of the three work circuits, hoisting, luffing, and slewing circuits, together with the feed and control-pressure circuit. The circuits appear in the same order in the hydraulic diagram.
Every hydraulic component is represented by a special symbol in the circuit diagram. The meaning of the symbols is explained in section “General” inthe Manual. The symbol for the reservoir is shown in several places in the diagram for greater simplicity of drawing; but there is naturally only one reservoir in actual fact.
CONTENTS
1. Installation of Units and Initial Adjustments
1.1 Adjusting the Zero Point of the Fuel Link Connecting Rod..............4
1.2 Pulse Generator..................................................5
1.3 Wiring...........................................................6
2. Operation Procedure of MCG unit
2.1 ABNORMAL indication lamp......................................7
2.2 FUEL LIMIT indication lamp......................................7
2.3 CONDITION indication lamp......................................7
2.4 CONTROL MODE indication lamp / select switch....................8
2.5 Parameter Adjustment Unit 8
2.5.1 Keyboard Department Constitution................................9
2.5.2 Operation Procedure • .........................................10
2.6 LAMP TEST switch ■ ................*............13
2.7 CAUSE RESET switch.................................13
2.8 TEST mode switch ..............................................13
2.9 Power switch....................................................13
2.10 Fuse..........................................................13
3. ADU unit Operation Procedure
3.1 Power switch..............................................14
4. Initial Adjustment
4.1 Turning on Power................................................15
4.2 Operation Check and Adjustment of Actuator........................16
4.2.1 Check of Actuator Position Feedback Signal........................16
4.2.2 Adjusting Feedback Signals of the Actuator Position................17
4.3 Check / Adjustment of Control Parameter............................19
4.3.1 Input Signal Scale Adjustment (Hardware System)..................21
4.4 Adjusting Speed Setting Signals
4.4.1 Adjusting the Speed Setting Signal 1 (W/H)........................23
4.4.2 Adjusting the Speed Setting Signal 2 (C/R)........................23
4.5 Adjusting the Actuator Position Limiter
4.5.1 Adjusting the Maximum Limiter..................................24
4.6 Adjusting the Scavenging Air Pressure Signal
4.6.1 Adjusting the Zero Pint of the PI Converter........................24
4.6.2 Adjusting the Scavenging Air Pressure Feedback Signal............24
5. Adjustment Procedures for Ten-key Data
5.1 Adjusting Speed Setting Signals
5.1.1 Adjusting the Speed Setting Signal (Control Position 1)............25
5.1.2 Adjusting the Speed Setting Signal (Control Position 2)............26
5.2 Emergency Slowdown............................................27
5.3 Adjusting the Scavenging Air Pressure..............................27
5.4 Starting Control Parameters
5.4.1 Actuator Dash Position at Starting................................28
5.4.2 Starting Control Keeping Time..................................28
5.4.3 Speed Setting Signal at Starting (Control position 2) * .............28
5.4.4 Actuator Retracting Amount at Starting............................29
5.4.5 PID Constants for Starting......................................29
5.4.6 Other Control Parameters for Starting............................30
5.5 Actuator Limiters
5.5.1 Torque Limiter................................................30
5.5.2 . Scavenging Air Pressure Limiter................................31
5.5.3 Maximum Limiter (MANUAL MAX. LIMIT)........................32
5.5.4 Maximum Limiter at the HIGH GAIN Mode........................32
5.5.5 Minimum Limiter..............................................32
5.5.6 Timers for Limiter Signals......................................33
5.6 Parameters for Detecting Abnormalities
5.6.1 Detecting a Break in the Speed Setting Signal Line..................34
5.6.2 Detecting a Break in the Scavenging Air Pressure Signal Line • • • • 34
5.6.3 Detecting an Abnormality in Actual Engine Speeds..................34
5.6.4 Detecting an Abnormality in the Actuator..........................35
5.7 Parameters for Droop Control......................................35
5.8 Filters
5.8.1 Upper Operating Level for the Jiggling Prevention Control..........36
5.8.2 Noise Filter for Speed Setting Signals............................36
5.8.3 Noise Filter for the Scavenging Air Pressure........................36
5.8.4 Noise Filter for Actual Engine Speeds............................37
5.9 Parameters for Dead Band Control................................38
5.10 Parameters for Governing
5.10.1 Normal PID Constants..........................................39
5.10.2 Selecting PID Constants changing Modes........................39
5.10.3 X-axis Signals for the PID Constants Function....................40
5.10.4 Proportional Gain (P) of the PID Constants Function..............41
5.10.5 Integral Time (I) of the PID Constants Function....................41
5.10.6 Differential Time (D) of the PID Constants Function................42
5.10.7 PID Constants for Emergency Control............................43
5.10.8 PID Constants for the High Gain Mode..........................44
5.10.9 Time Scheduler for Actual Actuator Positions....................45
6. Adjustment Procedures for Parameters
6.1 Adjustment at Starting
6.1.1 Adjustment If the Engine Stalls...........................46
6.1.2 Adjustment If the Engine Hunts..................................46
6.1.3 Adjustment If the Actual Engine Speed Increases Greatly After
Starting................................................46
6.2 PID Adjustment at Low Load
6.2.1 Adjustment If the Engine Hunts..................................47
6.2.2 Adjustment If the Engine Stalls..................................47
6.3 PID Adjustment at Middle Load
6.3.1 Adjustment If the Engine Hunts..................................47
6.4 PID Adjustment at High Load
6.4.1 Adjustment If the Engine Hunts..................................47
5.8 Filters
Fix the connecting rod to the governor actuator as follows:
1) After stopping the main engine, separate the connecting rod from the local control stand.
2) Move the fuel linkage by hand to the zero position.
3) Move the actuator by hand to the zero position.
4) After loosening the lock nut for the connecting rod, screw the rod connector in the actuator rod.
5) Adjust the rod length to match the connecting hole of the connecting rod with that of the local control stand.
6) Tighten the lock nut for the connecting rod.
1.2 Adjustment of zero side stopper
Adjust a zero side stopper as follows, so as not to interfere with a zero side stopper with an engine, when an actuator became a zero position.
1) An actuator is made a zero position.
2) Set the rack minimum position to -1 mm or less in the actuator position.
03-070 NABCO-00
Download [17 KB]
student   21-Mar-2013 15:53
станьте кто-нить на раздачу пожалуйста. не могу скачать, очень нужно.
заранее огромное спасибо!
Digital Temperature Micro-controller X Model: PXZ - Fuji Electric/ Instruction and Operation…
KGW Double Deck Crane EH 2x25t - 22m Lo-Ro Carrier - Krupp Fordertechnik [2002, PDF]
MAN B&W - AutoChief® C20 Kongsberg Propulsion Control System Instruction Manual for MAN B&W…
The time now is: Today 15:53
