billakos1601 ®   01-Sep-2015 09:22
International Life-Saving Appliances Code (LSA Code) 2010 Edition (ID982E)
Year: 2010
Author: IMO
Edition: 2ND
ISBN: 9789280115079
Pages count: 290
Description: The International Life-Saving Appliances (LSA) Code was adopted by the Maritime Safety Committee in June 1996 by resolution MSC.48(66). It provides international requirements for the life-saving appliances that are required by chapter III of the 1974 SOLAS Convention, including personal life-saving appliances (for example, lifebuoys, lifejackets, immersion suits, anti-exposure suits and thermal protective aids), visual aids (parachute flares, hand flares and buoyant smoke signals), survival craft (liferafts and lifeboats), rescue boats, launching and embarkation appliances and marine evacuation systems, line-throwing appliances; and general alarm and public address systems.
Introduction
The Code was made mandatory by resolution MSC.47(66) under SOLAS regulation III/3.10, whereby regulation III/34 determines that all life-saving appliances and arrangements shall comply with its requirements. The Code entered into force on 1 July 1998 and since then has been amended in accordance with SOLAS Article VIII as follows:
.1 by the May 2006 amendments, which were adopted by resolution MSC.207(81) and will enter into force on 1 July 2010;
.2 by the December 2006 amendments, which were adopted by resolution MSC.218(82) and entered into force on 1 July 2008; and
.3 by the 2008 amendments, which were adopted by resolution MSC.272(85) and will enter into force on 1 July 2010.
The consolidated text of the LSA Code in the present publication incorporates the above three sets of amendments, including the two sets entering into force on 1 July 2010, since they were deemed to have been accepted, in accordance with the SOLAS amendment procedures, on 1 January 2010 and will therefore automatically enter into force on 1 July 2010.
Recommendations on the testing of life-saving appliances were first adopted by the IMO Assembly in 1991, by resolution A.689(17). In 1998 the MSC, recognizing the need to introduce more precise requirements for the testing of life-saving appliances and recalling that it had amended the recommendations on several occasions since their adoption, adopted the Revised Recommendation on Testing of Life-saving Appliances (resolution MSC.81(70)), effectively replacing resolution A.689(17). Since then, the Revised Recommendation has again been amended several times, in the main corresponding to the associated amendments to the LSA Code described above, and the present publication contains the consolidated text including the amendments adopted by MSC 80 (resolution MSC.200(80)), MSC 82 (resolution MSC.226(82)) and MSC 85 (resolution MSC.274(85)).
The Code of practice for the evaluation, testing and acceptance of prototype novel life-saving appliances and arrangements, adopted by the Assembly in 1983 by resolution A.520(13), is intended to cater for prototype novel life-saving appliances and arrangements which may be developed and do not fully meet the requirements of chapter III of the 1974 SOLAS Convention but provide the same or higher safety standards.
Life-Saving Appliances Including LSA CODE Spanish Version - IMO [2017, PDF]
Life-Safing Appliances including LSA Code - Collective [2010, DjVu]
LSA CODE 2008 - IMO [2008, PDF]
International Code for Fire Safety Systems (FSS CODE) - IMO [2007, PDF]
International Code of Safety for Diving Operations (DIVING Code) - IMO [2023, PDF]
SOLAS Consolidated Edition - IMO [2009, PDF]
Procedures for Port State Control, 2019 (Resolution A.1138(31)) - IMO ASSEMBLY [2020, PDF]
SOLAS Training Manual (Lifesaving Appliances & Survival Techniques) - I.C. Brindle [2003, PDF]
International Code for Application of Fire Test Procedures (FTP CODE) - IMO [2012, PDF]
  • Topic closed
The time now is: Today 15:04
