seanavigator847 ®   28-May-2026 22:26
Maersk - Repair manual for dry steel containers
Year: 2014
Author: Maersk
Pages count: 169
Description: This manual has been prepared with the intention to inform about box repairs on containers, and to educate the repair shops in using the correct method and procedure of repair to containers. The manual is provided with a set of decision diagrams, which will assist you in choosing the correct repair method. Additional to this information about types of materials used in the containers is provided. In general, these materials are the minimum requirements for strength and quality. Better materials can
be used if the specified material not available. Only the most common repairs are described in this manual.
MAERSK REPAIR MANUAL FOR STEEL DRY CONTAINERS.pdf
Download [15 KB]
IICL: Repair Manual for Steel Freight Containers, 5th Edition - IICL [2006, PDF]
IICL: Guide for Flatrack Container Inspection - IICL [2003, PDF]
Materials used for boat construction - wooden boat [PDF]
DNV RECOMMENDED PRACTICE DNV-RP-C104 Self-elevating units 2022 - DNV [2022, PDF]
Lashing and Securing of Deck Cargoes - J.Knott [2002, PDF]
Shipbuilding and Repair Quality Standard (Rec.47) Corrected - IACS [2025, PDF]
Navy Tools and Their Uses - DEPARTMENTS OF THE ARMY, NAVY, AIR FORCE AND MARINE CORPS [2013, PDF]
Marine Chain Cable Pocket Guide - Lloyd’s Register [2011, PDF]
The time now is: Today 21:56
