vitbar192 ®   06-May-2026 10:13
Building the U.S.N. Picket Boat No.1 1864 (MS2261)
Year: 2010
Author: Crane B.
Publisher: Model Shipways
Pages count: 16
Description: U.S.N. PICKET BOAT No. 1, 1864 MS2261 The Boat That Sunk The Albemarle Picket Boat Number One, a steam launch, was built in 1864 to support of the U.S. Navy's blockade of the Confederacy. Outfitted with a spar-torpedo, she could also attack larger enemy vessels. On the dark night of 27-28 October 1864, Lieutenant William B. Cushing and his crew took Picket Boat Number One up river to Plymouth, North Carolina. In one of the Civil War's most daring naval actions, they attacked the Confederate ironclad Albemarle, sinking it with the spar torpedo. Only Lt. Cushing and one other man escaped, and Picket Boat Number One was lost, but the Union forces on the North Carolina sounds were freed of the great threat presented by the continued existence of the Albemarle. Model Shipways historically accurate kit recreates Picket Boat No. 1 in great detail. You build your model much the same way as the real boat was built almost 150 years ago, using many of the same materials. Only, your job will be much easier, thanks to the laser cut basswood parts and ready-made fittings, 5 large sheets of plans and illustrated step-by-step instruction manual. Laser-cut basswood parts facilitate plank-on-frame interior construction. High quality, flexible basswood strips are supplied for hull planking. Britannia metal fittings, brass and aluminum parts are used for deck furnishings, including a miniature steam engine, pump & 12-pounder Dahlgren Howitzer.
DIMENSIONS: L: 650 mm x H: 260 mm x W: 70 mm
SMOOTH CONSTRUCTION: Historically accurate and Highly Detailed Basswood parts are laser-cut for easy construction
DETAILED INSTRUCTIONS: 16-pages fully illustrated instructions manual and five full size plans will guide you through the whole building process for a smooth and successful experience.
LIFETIME GUARANTEE: In case a piece gets lost or damaged, we will replace for free. No questions asked
MADE IN THE USA. Designed and manufactured in our Florida factory, since 1976
Not
Crane B. Building the U.S.N. Picket Boat No.1 1864 (MS2261), 2010.pdf
Download [670 B]
Steam paddle cutter Harriet Lane 1857 (MS2010) - Lankford B. [2010, PDF]
Civil War Commando: William Cushing and the Daring Raid to Sink the Ironclad CSS Albemarle - jerome ...
Clippers of the Port of Portsmouth and the Men Who Built Them - Brighton R. [1985, PDF]
Gunther Prien and U-47: The Bull of Scapa Flow: From the Sinking of the HMS Royal Oak to the Battle ...
The Spanish U-Boat (The Post-War U-Boats Book 2) - John Peterson [2014, PDF]
Iron Dawn: The Monitor, the Merrimack, and the Civil War Sea Battle that Changed History - Richard S...
Imperial Japanese Navy Destroyers 1919–45 (2): Asashio to Tachibana Classes ( - Mark Stille [2013, P...
Betrayal - Julian stockwin [199?]
Torpedo Run: The Story of WWII Submarine Hero Eugene B. Fluckey - Don Keith (Vincent Caruso) [2022, ...
Modeling the HMS ’Bounty’s Launch 1789 (Instruction manual) - Crane B. [2006, PDF]
The time now is: Today 12:29
