twicer ®   05-May-2026 10:28
PSC Pre-port Arrival Quick Reference and Checklist
Year: 2026
Author: ABS
Genre: CheckList, Guide
Publisher: American Bureau of Shipping (ABS)
Edition: March 2026
Pages count: 24
Description: Preparation for Port State Control
Initially, Port State Control (PSC) inspection usually consists of a visit on board by the local PSC inspector to verify that necessary certificates and documents are valid. The initial visit also gives the inspector an opportunity to judge the general appearance and condition of the vessel. Detailed inspections are warranted when the PSC inspector observes areas of concern as per the PSC regimes internal criteria (and any Concentrate Inspection Campaign). The vessel may be then identified as a high-risk vessel and/or a vessel of concern.
Port State Control Checklist (fillable)
The quick reference guide and associated checklist are recommended to prepare the vessel for arrival into port. It is designed to complement on-board routine maintenance programs as well as pre-port arrival and departure checks required by international regulations. If any of the items identified in this guide are not in satisfactory working condition, the crew should take appropriate actions to remedy the situation. If any identified deficiencies cannot be rectified, PSC should be notified prior to arrival.
The guide is organized according to major PSC categories and areas of concern. For each major category, the common deficiencies have been identified for your reference.
Additional info:
Guidance for Reducing Port State Detentions & PSC Check List - ABS [2020, PDF]
Author: ABS | Year: 2020 | Language: english | Format: PDF | Quality: eBook | Pages count: 76 | Genre: Guide
Open released by twicer
PSC Pre-port Arrival Quick Reference and Checklist.pdf
Guidance for Reducing Port State Detentions - ABS [2016, PDF]
Port State Control Quarterly Report Q4 2025 - ABS [2026, PDF]
ABS Port State Control Quarterly Report Q4 2023 - ABS [2024, PDF]
Port State Control Annual Report 2023 - ABS [2024, PDF]
Port State Control Quarterly Reports Q1 and Q2 2024 - ABS [2024, PDF]
Report of the 2017 Concentrated Inspection Campaign (CIC) on Safety of Navigation, including ECDIS -...
Port State Control Quarterly Report (Quarter 1) - ABS [2025, PDF]
Port State Control Annual Report - ABS [2020, PDF]
Port State Control Quarterly Report Q3 - ABS [2021, PDF]
The time now is: Today 17:13
