Guidance for Reducing Port State Detentions & PSC Check List
Year: 2020 Language: english Author: ABS Genre: Guide Publisher: ABS Format: PDF Quality: eBook Pages count: 76 Description: This quick reference guide and associated checklist are recommended to be used by the crew in preparation of the vessel’s arrival into port. It is designed to complement on-board routine maintenance programs as well as pre-port arrival and departure checks required by international regulations. If any of the items identified in this guide are not in satisfactory working condition, the crew should take appropriate actions to remedy the situation. If any identified deficiencies cannot be rectified, Port State Control should be notified prior to arrival. The guide is organized according to major PSC categories and areas of concern. For each major category, the common deficiencies have been identified for your reference. Download and print the A4-sized PDF checklist or guidance brochure, which is designed to be used onboard. Port State Control Check List: Use the ABS check list before arrival to complete arrival and departure checks by international regulations, such as ISM, ISPS, and ILO-MLC. Issue Date: Nov, 29 2020 Version 2 ABS Port State Control Quarterly Report 4Q 2020 Included. .
**************************************************************** File Listing For: [***\ABSPSC] on 25/2/2021 **************************************************************** ABS Port State Control Quarterly Report 4Q 2020.pdf [3 MB] Guidance for Reducing Port State Detentions v2.pdf [2 MB] Pre-port Arrival Quick Reference and Downloadable Check List.pdf [1 MB]
Author: ABS
Publisher: ABS
Pages count: 76
Description:
****************************************************************File Listing For: [***\ABSPSC] on 25/2/2021
Notice from: twicer
https://seatracker.me/viewtopic.php?t=68900
ABSPSC
Download [9 KB]
Share
