SerTan ®   22-Nov-2017 04:47
Guidance for Reducing Port State Detentions
Year: 2016
Author: ABS
Publisher: ABS
Edition: 1.3
Pages count: 44
Description: This quick reference checklist guide is based on data gathered from ABS vessels that have been involved in Port State interventions or detentions. The guide should be used by the vessel’s crew prior to arrival into port. The categories and items identified in this guide are items that have been identified as top Port State detention items on board ABS classed vessels.
This guide should be used in conjunction with the normal pre-port arrival and departure checks required by international regulations and in conjunction with on board routine maintenance programs. If any of the items identified in this guide are not in good working condition, the crew should take appropriate steps to remedy the situation prior to arrival into port.
The guide is organized according to major categories as well as items identified by Port State Control (PSC) as areas of concern. For each major category the top items have been identified for your easy reference.
Guide for reducing PS detentions (ABS).pdf
Guidance for Reducing Port State Detentions & PSC Check List - ABS [2020, PDF]
Arrival Checklist for PSC - ClassNK - ClassNK [2019, PDF]
PSC Pre-port Arrival Quick Reference and Checklist - ABS [2026, PDF]
Detainable Deficiencies Guidance and PSC Check List - DBS [2021, PDF]
Arrrival СheckList for PSC - ClassNK [2016, PDF]
Check Lists to Prepare for PSC Inspections, rev. 04/2015 - BV [2015, PDF]
Port State Inspection-Poket Checklist-CLASS NK - Class NK [2010, PDF]
Documentation control checklist - Novomar Assesoria Empresarial Ltda [20??, PDF]
Good Maintenance Onboard Ships - ClassNK [2017, PDF]
Marine Fire Safety Pocket Checklist, Reducing the risk of Port State Control detentions - Lloyd’s & ...
The time now is: Today 03:06
