twicer ®   21-Apr-2026 18:39
PortToPort Desktop | Marine Distance Tables (Portable Version)
Year: 2026
Version: 6.1.26.0
Developer: CherSoft Ltd
64-bit OS compatibility: yes
System Requirements: Windows any Version
Localization: English
Crack: Not needed. Pre-K'ed
Description: "PortToPort Desktop" - the desktop version can be installed on a Windows PC and provides offline access to the AtoBviaC Marine Distance Tables.
PortToPort Desktop is part of the AtoBviaC distance calculations software range. This desktop application does not need the internet, making it ideal to be used on ships at sea. It gives access to the AtoBviaC Marine Distance Tables via Windows PCs, making sure the marine distances and route calculations produced are accurate and realistic. The Distance Tables used are automatically updated to use the latest version of the Distance Tables whenever a new release is made, ensuring that subscribers always have access to current distance data.
Offline access - PortToPort Desktop can be installed on a Windows PC to provide offline access to AtoBviaC Marine Distance Tables.
Accurate & realistic distances - Route legs reviewed by experienced Mariners to ensure route calculations are accurate and reliable.
Updates - The Distance Tables used in PortToPort Desktop are updated and expanded regularly to add new ports and to adjust routes and distances to reflect changes in regulations, IMO Ships' Routeing, non-IMO routing schemes, Notices to Mariners and environmental factors. Issue new releases every two to three months.
Included features - Accurate distances, the ability to create multi-leg voyages using over 3300 'distance table' ports with full control over routing between ports.
Tables updated to Admiralty Notices to Mariners 2026 Week 11 | Distance Tables Date: Wednesday, 25-03-2026
Additional info: * Portable Version, No installation required. Pre-K'ed!
Notable areas of Change
Port approaches reviewed
Minor changes have been made to approaches to the following ports, prompted by review or due to the release of updated charts or other information in Notices to Mariners; distances to/from these ports may have changed
Algeciras
Astoria
Bacalod
Baubau
Caldera
Chacabuco
Cherry Point
Chiba
Davao
Es Sider
General Santos
Kali Limenes
Luanda
Malaysia Waters
Midway Island
Mindanao
Mocamedes
Nador
Pelabuhan Wayame
Portland
Prince Rupert
Sevastopol
Shimizu
Sriracha
Tangiers
Varna
Villanueva
Other sea areas reviewed
Minor changes have been made to the route network in the following sea areas, either prompted by review or due to the release of updated charts or other information in Notices to Mariners; distances for routes transiting these areas may have changed by a small amount:
Algeria
Croatia
East Coast of the USA
English Channel
Indian Ocean
Mediterranean
North Sea
Norwegian Sea
South China Sea
Waters off Denmark
Install Version of the same:
PortToPort Desktop | Marine Distance Tables v.6.1.26.0 - CherSoft Ltd [2025]
Developer: CherSoft Ltd | Year: 2026 | Localization: English | Crack: Included (readme.txt for details) | Platform: Windows | 64-bit OS compatibility: yes
Open released by twicer
PortToPort Desktop 6.1.26.0 Portable.exe
Download [15 KB]
Jethro   23-Apr-2026 08:57
Doesn't start. Only the splash screen appears for a few seconds. No readme.txt.
twicer ®   23-Apr-2026 09:37
113266Doesn't start. Only the splash screen appears for a few seconds. No readme.txt.
-----> try the following,
if you run the program from hard disk:
1. exit and/or close any program related to Porttoport Desktop, even using "Taskmanager"
2. Check if the C:\Users\"username"\AppData\Roaming\VOS folder is empty, delete all files if it is not, and then start the program again.
if you run from flash drive, delete unpacked data folder from root of flash drive.
3
ChemServe Miracle - Desktop Client - ChemServe GmbH [2023, PDF]
Passage Manager 6.0 + MetManager 7.0 - ChartCo [2016]
Xinutop: Dedicated Marine OS v.VDI version X86 2.3 - Frank Baudet [2019]
NavPac v.4.1.1 - HMNAO [2020]
IACS Blue Book - IACS [2019, PDF]
IACS Blue Book - IACS [2020, PDF]
Transas 4000 Navi-Planner 2017 v.3.01.347.0134 - TRANSAS [2017]
IACS Blue Book - IACS [2021, PDF]
The time now is: Today 08:14
