twicer ®   19-Nov-2025 20:51
KR-CON V23
Year: 2025
Version: 23.0.1
Developer: Korean Register
64-bit OS compatibility: yes
System Requirements:
- Windows 10 or higher
- 1GHz CPU or faster
- 512MB RAM or higher
- any ISO virtual disk mounting app
Localization: English
Crack: Not needed
Description: KR-CON, developed by Korean Register, is a comprehensive IMO Convention Database containing IMO Conventions, Codes, Resolutions and Circulars in English and Korean.
KR-CON is a portable electronic database containing a vast array of IMO instruments. It enables users to navigate the maze of IMO instruments swiftly and accurately through a variety of user-friendly functions. Users can browse the contents with the click of a mouse, and identify the regulations applicable to an individual ship simply by inputting its details. An intelligent search function allows specific contents to be found easily and quickly. Install version allows users to install KR-CON to their PC for faster experience.
KR-CON Version 23 Released 2025.04.01
Sources Used
KR-CON v.22 - Korean Register [2024]
Developer: Korean Register | Year: 2024 | Localization: English, Korean, Chinese | Crack: Not needed | Platform: Windows | 64-bit OS compatibility: yes
Открыть автор релиза svyberg
and
Korean Register Download KR-CON Application
How to Use
1. Mount the ISO disk - Disk_install/KR-CON V23.iso file, using any virtual disk mounting app
2. Run the setup.exe file, from mounted (as a virtual drive) .iso disk and install the software. Ignore any Titles "KR-CON V22"
3. Copy and Replace the following files, from Replace/ folder:
a. Database/krcon22.db --> to c:/PrgramData/KOREAN REGISTRY/KR-CON V22/Database/
b. IMDGCode_Files/IMO Dangerous Goods List (41-22).pdf --> to c:/PrgramData/KOREAN REGISTRY/IMDGCode/Files
c. StatusOfConventions/ all .pdf files --> to c:/Programm Folder/KOREAN REGISTRY/KR-CON V22/StatusOfConventions/
4. enjoy! database updated up to KR-CON Version 23 (released 2025.04.01)
* to run the KR-CON program you need to keep the .iso file mounted, or othervise to copy full content of mounted ISO disk to USB stick.
* the New data file Files.iso has already been imported into the release and does not required updating.
KR-CON V23
Download [47 KB]
List V – List of Ship Stations and Maritime Mobile Service Identity Assignments - ITU [2025, EXE]
TELchart v.3.5.32 [2011]
DNV Software Sesam Marine 2013 v.14 (sept 2019) - DNV [2019]
IACS Blue Book - IACS [2019, PDF]
IACS Blue Book - IACS [2020, PDF]
Portable Gas Detectors CBT v.6.0 - Martin Bruusgaard AS [2016]
IACS Blue Book - IACS [2018, PDF]
IACS Blue Book - IACS [2021, PDF]
BAPLIE Manager v.1.0.5 - Yury Komar [2024]
The time now is: Today 04:28
