Cabral1500 ®   04-May-2024 22:34
Guidelines for the design of maritime structures
Year: 2005
Author: Australian Standard
Publisher: Australian Standard
ISBN: 0 7337 6858 X
Pages count: 58
Description: This Standard was prepared by Standards Australia Committee CE-030, Maritime Structures.
The objective of this Standard it to provide designers and regulatory authorities of structures located in the marine environment with a set of guidelines and recommendations for the design, preservation and practical applications of such structures. These structures can include fixed moorings for the berthing of vessels, piles and other parts of a substructure, wharf and jetty decks, building substructures over waters, etc.
This Standard has been prepared as a guideline only, to provide advice and recommendations for maritime structures. Clauses in this document are written using informative terminology and should not be interpreted otherwise. The requirements of a maritime structure and its associated facilities should be determined for the individual application. This Standard should be used in conjunction with the relevant materials and design Standards.
As_4997_2005_guidelines_for_the_design_o.torrent
Download [1 KB]
IALA Guideline No. 1098 (On the Application of AIS - AtoN onBuoys) + IALA Guideline No. 1096 (Antici...
Technical Guidelines - Marine & Offshore Insulation - ROCKWOOL Technical Insulation [2016, PDF]
Guidance Notes on Strength Assessment of Independent Type C Tanks - ABS [2022, PDF]
Guidelines on the medical examinations of seafarers - International Labour Organization [2011, PDF]
Hybrid Electric Power Systems for Marine and/or Offshore Applications - ABS [2022, PDF]
Noble Denton marine services - certification for towing vessel approvability - DNV GL [2017, PDF]
Timber in boatbuilding - Hearth J.H. [1977, PDF]
Maritime works. Code of practice for design of fendering and mooring systems - Technical Committee B...
DNV RECOMMENDED PRACTICE DNV-RP-C104 Self-elevating units 2022 - DNV [2022, PDF]
Mariner’s Handbook for Australian Waters Edition 5.0 AHP20 - Australian Hydrographic Office [2019, P...
The time now is: Today 13:31
