twicer ®   26-Dec-2021 18:16
Guidance Notes on Strength Assessment of Independent Type C Tanks
Year: 2022
Author: ABS
Genre: Class Guideline
Pages count: 46
Description: In the ABS Guide for Building and Classing Liquefied Gas Carriers with Independent Tanks (LGC Guide),
the procedure for the strength evaluation of hull, tank, and support structures has been developed for gas
carriers with independent type gas tanks. However, the LGC Guide puts increased emphasis to the hull
structure and the independent Type B prismatic tanks in gas carriers. These Guidance Notes provide a
procedure for the structural assessment of Type C independent cargo/fuel tank and supporting structures
under static and dynamic loads to supplement the LGC Guide.
These Guidance Notes define design load cases, which include standard load conditions, accidental load
conditions, and test load conditions for yielding and buckling strength assessment, and also design load
cases including wave-induced high cycle fatigue load and cargo/fuel loading/unloading induced low cycle
fatigue load conditions for fatigue assessment.
Guidance Notes on Strength Assessment of Independent Type C Tanks 2022.pdf
Download [14 KB]
Guideline Liquefied gas carriers with independent prismatic tanks of type A and B DNV-CG-0133 - DNV ...
Liquefied gas carriers with independent cylindrical tanks of type C - DNVGL-GL [2016, PDF]
GUIDE FOR BUILDING AND CLASSING LIQUEFIED GAS CARRIERS WITH INDEPENDENT TANKS - ABS [2018, PDF]
Requirements for Building and Classing Floating Offshore Liquefied Gas Terminals - ABS [2024, PDF]
ABS - Guide for Building and Classing Liquefied Gas Carriers with Independent Tanks - ABS [2021, PDF...
Guide for Slamming Loads and Strength Assessment for Vessels - ABS [2021, PDF]
Guide for Building and Classing Liftboats - ABS [2022, PDF]
Rules for the Classification and Construction of Sea-Going Ships - Russian Maritime Register of Ship...
The time now is: Today 00:13
