NNT ®   26-Mar-2015 11:00
Maritime works. Code of practice for design of fendering and mooring systems
Year: 1994
Author: Technical Committee B/525
Genre: Reference book
Publisher: BSI
Edition: 2nd
ISBN: 0 580 22653 0
Pages count: 50
Description: Since 1985 many things have changed relating to mooring and fendering, including vessel shape and size, self-propelled docking and commercial pressures on facility location. Both vessel sizes and berth construction have increased significantly meaning that the advice in the existing version of BS 6349-4 needed to be updated. A full revision of BS 6349-4 was therefore required.
Who should use BS 6349-4?
The maritime market
Infrastructure and Environment engineers for ports
Project management consultants for maritime/ports
Port authorities
Private consulting practices
Planning agencies
Manufacturers and suppliers of fenders and vessel berthing aids (Trellebourg Marine Systems)
[British_Standard]_Code of practice for design of endering and mooring systems
Download [1 KB]
BS 6349-4-2014 - Maritime works – Part 4-Code of practice for design of fendering and mooring system...
Planning And Design Guidelines For Small Craft Harbors - ASCE [2012, PDF]
Marine Structures Engineering- Specialized Applications - Gregory Tsinker, Ph.D.,P.E. [1995, PDF]
DP Operations Guidance - Dynamic Positioning Committee [2021, PDF]
Maritime structures - Part 1: Code of practice for general criteria - British Standard [2003, PDF]
Port Designer’s Handbook - Carl A. Thoresen [2014, PDF]
The Workboat Code - Maritime and Coastguard Agency [2018, PDF]
The Mooring Series: The theory of mooring Safe mooring practice, Maintenance of mooring systems - Vi...
Gap Analysis and Mapping of VIQ version 7 vs VIQ version 6 (Rev.1) - INTERTANKO [2018, PDF]
Small boats for small budgets - Oakley J. [1946, PDF]
The time now is: Today 23:28
