twicer ®   20-Nov-2024 20:03
Model Ballast Water Record Book
Year: 2024
Author: Lloyd's Register
Genre: Documentation
Publisher: Lloyd's Register and IMO
Edition: 2024
Format: PDF, DOCx
Pages count: Multiple
Description: Having a Ballast Water Record Book (BWRB) onboard is a requirement of the BWM Convention (Reg. B-2).
Fillable Model BWRBs, which meet the correct Convention format, can be found here. Useful guidance on completion of BWRB entries can be found in BWM.2/Circ.80/Rev.1 - Guidance on ballast water record-keeping and reporting. IMO resolution MEPC.369(80) includes amendments to the BWM Convention which change the format of BWRBs, and enters into force on 1 February 2025.
A diagram identifying the ballast tanks of the ship, corresponding to the Ballast Water Management Plan, including any multi-use tank, space or compartment designed to allow carriage of ballast water, is integral to and shall be a part of this Ballast Water Record Book.
You can buy it on https://www.lr.org
Ballast Water Management: Ballast Water Management Plans & Ballast Water Record Books - Lloyd’s Regi...
Ballast Water Record Book RML-124 Rev. 2025 - Liberian Registry (LISCR) [2025, PDF]
Ballast Water Management Plan [model] - Lloyd’s Register and IMO [2023, DOC/PDF]
Guidance For Recording Entries In The Ballast Water Record Book (BWRB) - LMA [2023, PDF]
Ballast Water Record Book RML-124 Rev. 2024 - LISCR [2024, PDF]
Ballast Water Management Plan DNV template - DNV [2017, PDF]
Ballast Water Management Record Book requirements - DBS [2022, PDF]
Future IMO and ILO Legislation (Spring 2024) - Lloyd’s Register [2024, PDF]
LR Ballast Water Management Plan Template D2 Standard 2025 - LR [2025, DOCx]
Resolution MEPC.328(76)_2021 Revised MARPOL Annex VI - IMO MEPC [2021, PDF]
  • Topic closed
The time now is: Today 14:38
