namemamun ®   18-Dec-2023 13:39
On Shore Power Supply and LNG
Year: 2015
Author: TrainMoS II
Genre: Presentation
Pages count: 83
Description: Onshore power supply (OPS) is one of the
strategies recommended by the several
organizations to reduce the environmental
impact of seagoing vessels in ports.
OPS replaces auxiliary engines at berth
When berthed, ships require electricity to
support activities like loading, unloading,
heating and lighting and other onboard
activities.
Today, this power is generally provided by
auxiliary engines that emit carbon dioxide
(CO2) and air pollutants, affecting local air
quality and ultimately the health of both
port workers and nearby residents. The
same holds for noise nuisance.
As an alternative to onboard power
generation, vessels can be hooked up to an
onshore power supply, i.e. connected to the
local electricity grid. In this way ships’
operations can proceed uninterrupted,
while eliminating negative side‐effects.
On Shore Power Supply and LNG.pdf
Download [5 KB]
Onshore Power Supply Systems | Preliminary Design Recommendations for Tankers and Terminals - OCIMF ...
Energy from the sea for seagoing vessels - RMU [2010, PDF]
Onshore Power Supply Systems: Recommendations for Tankers and Terminals - OCIMF [2025, PDF]
Safety and health in ports - ILO [2005, PDF]
Gas as a Marine Fuel - An Introductory Guide - SGMF [2019, PDF]
Sustainability Whitepaper LNG as Marine Fuel - ABS [2020, PDF]
Manual of Best Management Practices For Port Operations - Great Lakes Maritime Research Institute [2...
Emission Capture and Control at Berth: Preliminary Safety Recommendations - OCIMF [2025, PDF]
CODE OF PRACTICE FOR THE SAFE LOADING AND UNLOADING OF BULK CARRIERS JUNE - Australian Maritime Safe...
IEEE 45 Standard_Recommended Practice for Electrical Installations on Shipboard-2002 - IEEE [2002, P...
The time now is: Today 22:04
