twicer ®   07-Feb-2025 22:29
Emission Capture and Control at Berth: Preliminary Safety Recommendations
Year: 2025
Author: OCIMF
Genre: Instruction, Reference book
Publisher: OCIMF
Edition: 1st (January 2025)
Pages count: 31
Description: The adoption of Emission Capture and Control (ECC) can bring environmental advantages to maritime operations in ports and terminals. By using ECC while at berth, ships can reduce their emissions, contributing to improved local air quality and aiding in compliance with environmental regulations.
This interim information paper aims to provide minimum functional requirements for the safe application of barge-based ECC to oil, chemical and oil product tankers operating at onshore conventional berths, such as piers, jetties and quays. It highlights critical risks and technical and operational challenges and identifies potential preventive measures to safely apply a barge-based ECC.
This paper highlights critical risks and technical and operational challenges and identifies potential preventive measures to safely apply a barge-based ECC. An OCIMF guide covering additional aspects of the safe application of ECC to tankers, including the management of interfaces, will follow this paper.
Emission Capture and Control at Berth.pdf
Download [422 B]
Onshore Power Supply Systems | Preliminary Design Recommendations for Tankers and Terminals - OCIMF ...
Onshore Power Supply Systems: Recommendations for Tankers and Terminals - OCIMF [2025, PDF]
Cyber Resilience of on-board Systems and Equipment E27 - IACS [2022, PDF]
Virtual Arrival Optimising Voyage Management and Reducing Vessel Emissions - an Emissions Management...
Methanol Bunkering: technical and operational advisory - ABS [2024, PDF]
Recommendation for converting Inland Tank-Barges from Open to Closed Cargo Operations - OCIMF [2024,...
SIGTTO Information Paper no. 5 - The Ship/Shore Interface - Communications Necessary for Matching Sh...
Guidelines for the Control of Drugs and Alcohol in the Maritime Industry - OCIMF [2024, PDF]
Guidelines for the Handling, Storage, Use, Maintenance and Testing of STS Hoses - OCIMF [2021, PDF]
Hazardous Chemicals Handbook - Phillip Carson and Clive Mumford [2002, PDF]
The time now is: Today 03:49
