namemamun ®   18-Dec-2023 12:11
Piping Practice Guide Line
Year: 2008
Author: Shipyard
Pages count: 34
Description: This is a practical guideline for piping fabrication in shipyard.
Its not so exhaustive.
For exhaustive and detailed engineering, there are classification rules.
This gives a primary knowledge for field technicians.
A. pipe piece welding
B. Anti-corrosion treatment
C. Pipe support
D. Penetrations
E. Pipe branch
F. Pipe joint
G. Recommendation for tankers
Piping Practice Guide Line.pdf
Download [10 KB]
Piping Systems Manual - Brian Silowash [2010, PDF]
Wave loads - DNV GL [2018, PDF]
Hydraulic Piping Standard Handbook - GS-Hydro Corporation (Finland) [214, PDF]
Ship Construction, 7th Edition - D. J. Eyres, G. J. Bruce [2012, PDF]
Electrician’s Guide to Control and Monitoring Systems - Albert F. Cutter Sr. [2010, PDF]
A Master’s Guide To: Ships Piping - Eric Murdoch [2012, PDF]
Guidance of Welders Qualification Tests - ClassNK [2022, PDF]
The Basics Of Gas Tungsten Arc Welding [2022, MP4]
SMAW / MMA Shielded Metal Arc Welding/Manual Metal Arc Welding [2024, MP4]
The time now is: Today 18:40
