namemamun ®   14-Dec-2023 21:55
High speed Aluminium vessels - Design guide
Year: 2012
Author: Ship Structure Committee, SSC
Pages count: 106
Description: Aluminum has become popular as a structural material in many industries, and the maritime industry is no exception. Shortly
after a smelting process was discovered and made aluminum a commercially available material, it was being used
experimentally in the construction of marine vessels. Throughout the decades since that time, aluminum has been used in a
number of different ships with varying levels implementation and varying degrees of success.
The wide range of success in incorporating aluminum into the structural design has been a result of the level of understanding
of the properties of the alloys and the ability of the designer to take advantage of the positive aspects while avoiding pitfalls
and carefully designing around the considerations that are inherent in aluminum vessel design.
Recently, as the commercial maritime industry and government organizations have begun constructing high speed vessels,
aluminum has gained popularity as a structural material due to its high strength-to-weight ratio. However, ship designs must
also consider the other properties of aluminum.
This design guide has been written to provide a practical overview of the design process for large, aluminum high-speed
vessels. It describes aluminum alloys, the manufacturing and joining processes for aluminum, and the vessel structural
design and construction process.
HIGH SPEED ALUMINUM VESSELS DESIGN GUIDE.pdf
Download [5 KB]
Survey of Structural Tolerances in the United States Commercial Shipbuilding Industry - Ship Structu...
Aluminum Structure Design and Fabrication Guide: Aluminum Structure, Marine Structure, Aluminum Desi...
Ship-handling competence requirements for berthing and un-berthing large vessels - DNV GL [2014, PDF...
On Structural Design of High-Speed Craft - Razolf M. [2013, PDF]
AWS-D1.2-2014-structural-welding-code-aluminum - AWS [2014, PDF]
Soling Guide 1992-1995 - International Soling Association [1992, PDF]
A Comprehensive Guide to Maritime Cybersecurity - Mission Secure [2021, PDF]
Offshore Engineering and Production (Third Edition) - Angus Mather [2011, PDF]
ComposeIT v.4.1.1 - BV [2023]
The time now is: Today 03:36
