twicer ®   26-Jun-2023 19:13
Guidelines for Direct Load Analysis and Strength Assessment
Year: 2023
Author: ClassNK
Edition: 3rd (June, 2023)
Pages count: 35
Description: Ships need to be capable of ensuring and maintaining their structural functions wheneverthey are in service, and today’s ships are more diversified and larger than ever before. Thismeans that ClassNK is always in search of new technical knowledge, either from recentresearch or from organisations such as IACS (the International Association of Classification Societies), to incorporate into its technical rules.
At this time, in response to the revision in December 2022 of IACS Recommendation No. 34, which specifies the sea conditions, ClassNK issues this third edition of this Guidelines, which specifies the requirements for strength assessment based on the IACS document.
In a new comprehensively revised version of Part C of the Rules publicly released on June 2023, ClassNK fine-tuned the concept of structural strength evaluation, and the same is nowbeing done in this second edition of this Guidelines.
Guidelines for Direct Load Analysis and Strength Assessment ClassNK 2023.pdf
Download [5 KB]
Guidelines for Direct Load Analysis and Strength Assessment - ClassNK [2022, PDF]
Guidelines for Direct Load Analysis and Strength Assessment - ClassNK [2024, PDF]
Guidelines for Direct Load Analysis and Strength Assessment - ClassNK [2025, PDF]
Guidelines for Remote Survey - ClassNK [2025, PDF]
Common Structural Rules for Bulk Carriers | Status and Guidance - ABS [202x, PDF]
Rules for the Classification and Construction of Sea-Going Ships - Russian Maritime Register of…
Rules for the Classification Surveys of Ships in Service with Annexes - RMRS [2020, PDF]
Guidance Notes on Fire-Fighting Systems - ABS [2017, PDF]
Rule Requirements for Materials and Welding (Part 2) - ABS [2026, PDF]
Recommendation for conducting commissioning testing of Ballast Water Management Systems -…
The time now is: Today 16:29
