twicer ®   07-Oct-2024 18:12
Requirements for Nuclear Power Systems for Marine and Offshore Applications
Year: 2024
Author: ABS
Genre: Other
Edition: October 2024
Pages count: 70
Description: This ABS Requirements for Nuclear Power Systems for Marine and Offshore Applications has been
developed to provide requirements for design, construction, and survey for class review and approval of
vessels having onboard nuclear power system installations. This document specifies ABS requirements for
the mandatory notation Power Service (Nuclear) for nuclear power generation for purposes other than
self-propulsion. For the purpose of this document, the term “vessel” includes ships, barges, offshore units,
and installations.
These requirements refer to technical requirements found in the International Convention for the Safety of
Life at Sea (SOLAS) Chapter VIII: Nuclear Ships and Resolution A.491(XII) Code of Safety for Nuclear
Merchant Ships 1981. It is to be noted that Resolution A.491(XII) is dated, with some content considered
obsolete according to advances in nuclear technology applications. Resolution A.491(XII) applies to
nuclear-powered vessels implementing pressurized water reactors (PWRs) for propulsion. ABS recognizes
that the use of A.491(XII) for the design and construction of nuclear power service vessels is not
appropriate.
nuclearpower-systems-reqts_oct24.pdf
Requirements for Building and Classing Offshore Spaceports - ABS [2023, PDF]
Guide for Power Service for Marine and Offshore Applications - ABS [2022, PDF]
Requirements for Hydrogen Fueled Vessels - ABS [2023, PDF]
Guide for Smart Functions for Marine Vessels and Offshore Units - ABS [2021, PDF]
Guide for Portable Accommodation Modules - ABS [2021, PDF]
Guide for Smart Functions for Marine Vessels and Offshore Units - ABS [2019, PDF]
Hybrid Electric Power Systems for Marine and/or Offshore Applications - ABS [2022, PDF]
Rules for buliding and classing Floating Production Installations (FPIs) - ABS [2020, PDF]
Requirements for Onboard Carbon Capture and Storage - ABS [2022, PDF]
Cyber Resilience Guidance - ABS [2026, PDF]
The time now is: Today 08:55
