keyur ®   04-May-2023 19:36
Gap Analysis - Revised IGC Code vs IGC Code
Year: 2015
Author: Bureau Veritas
Genre: Normative document
Pages count: 216
Description: The IGC code was adopted in 1983 and entered into force in 1986. It has been regularly, though moderately, amended since then while substantial technological developments took place over the last years. A proposal that the IGC code be revised under the auspice of SIGTTO was submitted by the UK at the IMO MSC 83 on 3 July 2007 and agreed. SIGTTO has consequently been tasked to produce, with the support of the industry, a draft revised IGC code to be submitted to the IMO. Revision works started in 2008, where SIGTTO had a role of coordination of the industry working groups that were shaped to undertake these revision works (129 participants from 18 countries representing 48 entities). The Revised IGC Code was adopted on 22 May 2014 by Resolution MSC.370(93) It will apply to units whose construction begins on or after 1 July 2016. This document presents a gap analysis between the revised IGC Code and the previous IGC Code.
The aim of this document is to highlight differences between the new and previous requirements or the modifications in the technical provisions where applicable.
Download [7 KB]
ISM Code and guidelines on implementation of ISM (Electronic Edition) - IMO [2010, PDF]
Design and Operations of Double Hull Tankers - RINA [2004, PDF]
MODU CODE 2009 (CODE for the Construction and Equipment of Mobile Offshore Drilling Units) - IMO…
Guidelines for Excellent Living and Working Environment - ClassNK [2024, PDF]
LR Summary Report for the IMO Ship Design and Construction Ninth session (SDC 9) - Lloyd’s Register…
Compendium of Maritime Labour instruments - ILO [2021, PDF]
A guide to collision avoidance rules - A. N. Cockcroft and J. N. F. Lameijer [2012, PDF]
The time now is: Today 14:26
