Year: 2020 Language: english Playtime: 1h 3m Quality: WEB-DL Format: MP4 Video: H.264 1280x720 30 fps Audio: AAC 48.0 KHz x 320 Kbps Description: The technique of metal inert gas welding for beginners and advanced. What you'll learn In the course MIG and MAG welding part 1 you can learn about inert gas welding using practical examples Requirements No requirements needed Description In the course MIG and MAG welding part 1 you can learn about inert gas welding using practical examples.The optimal welding result depends one hundred percent on the gas flow, wire feed and the correct voltage. But what does the perfect weld seam or the perfect weld point mean and how do you get there? Furthermore, the hobbyist can acquire one or the other trick for his own workshop. The craft of MIG and MAG welding is comprehensibly explained on the basis of detailed error analyzes and a detailed explanation of which result arises from which initial situation. Overview Section 1: The basics of MIG welding Lecture 1 MIG welding Part 1 Lecture 2 Preperation of the welding panels Lecture 3 The technique of metal inert gas welding Lecture 4 The wire electrode Lecture 5 Holding the torch Lecture 6 The contact tip Lecture 7 Torch guiding, stinging, neutral and dragging Lecture 8 The torch distance Lecture 9 Butt welding Lecture 10 Closing holes Lecture 11 Fillet welds Lecture 12 Rounded fillet welds Lecture 13 The correct gas Lecture 14 Rising and vertical falling seam Lecture 15 Bonus material: Lead loading Beginners, students, trainees.,But also advanced hobbyists can use this course to fresh thier skills up.
MIG Welding Part 1
Playtime: 1h 3m
Quality: WEB-DL
Format: MP4
What you'll learn
Requirements
Description
Overview
MIG Welding Part 1
Download [15 KB]
Share
