janataly ®   10-Feb-2013 11:25
PIPE WELDING PROCEDURES
Year: 2003
Author: Hoobasar Rampaul
Genre: Руководство
Publisher: Industrial Press
Series: 2nd edition
ISBN: 0·8311·3141·1
Quality: OCR without errors
Number of pages: 249
Description: It is well known that only high quality pipe welds are acceptable in modern industry as the failure of a weld can disrupt the operation of a plant and be the cause of a serious accident with the possible loss of life and property. For this reason, a pipe welder must be a thoroughly qualified person in his craft. The objective of this book is to describe the techniques that will result in a successful pipe weld, which must be sound throughout as well as look good. The pipe welder will be provided with the related information necessary for him to do his job correctly. To be a successful pipe welder and achieve high quality pipe welds, requires practice in welding pipe. It cannot be learned by reading a book alone; however, if incorrect techniques are repeated, practice alone will never lead to successful pipe welding. Those who will take the time and effort to read this book will learn the correct techniques which, if practiced, will result in obtaining the skills required to be a successful pipe welder.
Pipe Welding Procedures.pdf
Download [14 KB]
Techniques in Welding Practices - Gopal Devar [2025, EPUB]
Underwater Welding of Offshore Platforms and Pipelines - American Welding Society [1981, PDF]
A Master’s Guide to Ship’s piping - Eric Murdoch [2021, PDF]
Welding For Dummies - Steven Robert Farnsworth [2022, PDF]
Ventilation and Energy Efficiency in Welding Shops - lexander Zhivov [2022, PDF]
Aluminum Boatbuilding - Sims Ernest [2000, PDF]
Guide For Materials and Welding for Stainless Steels, 2019 - ABS [2018, PDF]
Электродуговая сварка / ARC WELDING (Wall Mounting Co. Inc) [2000, AVI]
Guidance of Welders Qualification Tests - ClassNK [2022, PDF]
The time now is: Today 13:33
