Year: 2020 Language: english Playtime: 38m Quality: WEB-DL Format: MP4 Video: H.264 1280x720 30 fps Audio: AAC 48.0 KHz x 320 Kbps Description: Learning TIG welding What you'll learn TIG welding basics Requirements No requiremants Description In order to achieve high quality welding seams it is recommended to use the TIG welding process. This method delivers clean and even joints. The TIG welding method is especially appropriate when forming aluminium. This tutorial explains comprehensibly the basics of TIG welding with detailed explanation of which result arises from which initial situation and a detailed error analyzes. Overview Section 1: Introduction Lecture 1 Introduction to TIG welding Lecture 2 The preperation for TIG welding Lecture 3 The TIG welding process Lecture 4 The TIG butt seam Lecture 5 The TIG fillet weld Lecture 6 The vertical butt seam weld Lecture 7 The vertical TIG seam Lecture 8 The round fillet weld Lecture 9 The pointed fillet weld Beginners and advanced
TIG Welding Basics Part 1
Playtime: 38m
Quality: WEB-DL
Format: MP4
What you'll learn
TIG welding basics
Requirements
No requiremants
Description
Overview
Download [17 KB]
Share
