skipper3362 ®   31-Mar-2023 18:10
Fundamentals Of Laser Welding
Year: 2020
Playtime: 43m
Quality: WEB-DL
Format: MP4
Video: H.264 1280x720 30 fps
Audio: AAC 48.0 KHz x 320 Kbps
Description: An Introductory Study
What you'll learn
Overview of Laser Welding
Concept of keyhole welding
Laser and Process Efficiencies
Defects in Laser Welding
Methods to improve Laser Welding Efficiency
Requirements
Basics of Mechanical Engineering
Description
Laser Welding has gained fast-paced applications in most of the industrial applications. The advantages of Laser welding includes resulting in a high strength welds, using a low heat application, it gives an ultimate precision and it is also responsible for creating a complicated joint. In this MOOC learners will face some basic topics regarding laser welding such as the concept of the keyhole welding process, the parameters which affect the laser beam welding process, and the various methods which can be adapted to increase the laser beam welding efficiency. The MOOC is divided into three sections represented below:SECTION 1: Basics of Laser Beam WeldingSECTION 2: Laser and Process EfficienciesSECTION 3: Methods to improve efficiency
Overview
Section 1: Basics of Laser Welding
Lecture 1 Overview
Lecture 2 Concept of Keyhole Welding
Section 2: Laser and Process Efficiencies
Lecture 3 Beam Quality
Lecture 4 Laser Electro Optical Efficiency
Lecture 5 Welding Process Efficiencies
Lecture 6 Common defects in Laser Welding
Lecture 7 Absorption as the key to Welding Efficiency
Section 3: Methods to improve efficiency
Lecture 8 Surface Modifications
Lecture 9 Preheating Techniques
Lecture 10 Ambient Condition Modifications
Beginner in Laser Welding
Fundamentals of Laser Welding
Download [18 KB]
Non-Destructive Test (Welding Inspection) [2023, MP4]
The Basics Of Gas Tungsten Arc Welding [2022, MP4]
TIG Welding Basics Part 1 [2020, MP4]
Learn MIG Welding [2020, MP4]
All About Valves : Classification & Types [2022, MP4]
Ultimate Electrical Machines Course for Complete Beginners [2021, MP4]
Learn Basics of Hydraulic Machines in the most easiest way [2021, MP4]
Basics of Welding and Thermal Processes in Shipbuilding and Ship Repair - E.G. Burmistrov [2017, PDF...
Alignment of the shaft Engineering Maintenance [2021, MP4]
Fire Safety Engineering : Fire Pump [2022, MP4]
The time now is: Today 03:49
