skipper3362 ®   04-Mar-2023 18:31
Compressed Gas Cylinders Safety
Year: 2022
Playtime: 0h 32m
Quality: WEB-DL
Format: MP4
Video: H.264 1280x720 30 fps
Audio: AAC 48.0 KHz x 320 Kbps
Description: Safe use, handing, transport and storage of compressed gas cylinders in terms of precautions to be taken
What you'll learn
Learn about key Hazards associated with Compressed gas cylinders
Few gases used commonly in construction industries and their characteristics
What are the Conditions to store gas cylinders safely?
How to carry out the Inspection of gas cylinders before use?
How to manage damaged gas cylinders?
Summary of safe use, transport, storage and handing of compressed gas cylinders
Requirements
Basic knowledge on construction, able to understand English, knowledge on welding and cutting
Description
This course is created to improve the awareness on safe use of compressed gas cylinder in construction industry. Many fire and explosion incidents do happen commonly at construction industry. The root causes of the incidents area) Lack of knowledgeb) Inexperienced operatorsc) Lack of inspection and maintenance of gas cylindersd) Uncontrolled hot worke) Unsafe handling of gas cylinders and hose pipesf) Unsafe storage of gas cylindersg) Not prepared for emergency situation such as fire and explosionh) Not performing Hydro test on the cylinders to check its condition periodically.In this course,As far as practically possible, the course materials are prepared with lot of pictures clicked at the construction sites are added.Chapter 1- Introductions and objectives of the course is explainedChapter 2- The learner will be able to understand the hazards arising due to use, handling and storage of gas cylinders. Also learn about the characteristics of various gases commonly used in construction industry. Color codes for the gas cylinders used within European codes are explained in this chapter.Chapter 3- In this chapter, hazards of Oxygen and Acetylene is explained. Also, the hazard due to oxygen enrichment is briefed with prevention measures for such enrichment.Chapter 4- The learner will be able to understand how to identify the gas cylinders and the precautions to be taken during supply and transportationChapter5 – In this chapter, the safe storage of gas cylinders and safe securing of cylinders are explained illustratively.Chapter 6- In this chapter, the explosion proof requirement of electrical equipment used at the storage of gas cylinders is well explained. Also, the inspection and care of the hose pipes used for Oxygen- Acetylene cutting set is briefedChapter 7– The learner will be able to understand about the don’ts about the handling of gas cylinders, care for the cylinders and the importance of cleanliness of gas cylinders.Chapter 8 – This chapter explains about the general precautions to be taken for the prevention of fire and the use of gases inside confined space.Chapter 9 – The learner will be able to understand about the regulator checks on the cylinder and how to remove the damaged cylinders safely out of service. Also, how to execute the hot work safely to protect the surrounding services.Chapter 10 – In this deck, the summary of all precautions is briefed at a glance.
Overview
Section 1: Introduction
Lecture 1 Introduction
Section 2: Compressed gas cylinder safety - Part2
Lecture 2 Compressed gas cylinder safety - Part 2
Section 3: Compressed gas cylinder safety- Part3
Lecture 3 Compressed gas cylinder safety- Part3
Section 4: Compressed Gas Cylinder- Part4.mp4
Lecture 4 Compressed Gas Cylinder safety- Part4
Section 5: Compressed Gas cylinder safety- Part5
Lecture 5 Compressed Gas Cylinder- Part5
Section 6: Compressed Gas Cylinder safety- Part6
Lecture 6 Compressed gas cylinder-Part6
Section 7: Compressed Gas Cylinder safety- Part7
Lecture 7 Compressed gas cylinder-Part7
Section 8: Compressed gas cylinder safety-Part8
Lecture 8 Compressed gas cylinder- Part8
Section 9: Compressed gas cylinder safety- Part9
Lecture 9 Compressed gas cylinder safety- Part 9
Section 10: Compressed Gas Cylinder safety- Part 10
Lecture 10 Compressed Gas cylinder Safety -Part 10
Safety officers, welders , cutters, Supervisors, construction safety officers, Construction Engineers and Project Managers
Compressed Gas cylinders safety
Download [22 KB]
Code of Practice 7, The Safe Use of Oxy-Fuel Gas Equipment (Individual Portable or Mobile Cylinder S...
TIG Welding Entry Level [2023, MP4]
Ladder Safety [2023, MP4]
Nebosh-igc, Element-8,manual and Mechanical Handling Hazards [2022, MP4]
Hot Work & Fire Watch [20xx, MP4]
Ladder Safety 2 [2022, MP4]
Occupational Safety and Health: Hazard Communication [2022, MP4]
Safe Handling & Management of Compressed Gas Cylinder [2024, MP4]
Learn MIG Welding [2020, MP4]
Fire Safety Training Course [2022, MP4]
The time now is: Today 17:50
