chasto ®   06-Nov-2022 17:49
HAMWORTHY Gas Combustion Unit manuals and drawings
Year: 2012
Author: HAMWORTHY
Pages count: 2396
Description: Operation, maintenance and spare parts manuals for the Hamworthy Gas combustion unit.
The main purpose of the AMOxsafe Gas Combustion Unit (GCU) is to ensure
oxidisation of the Boil Off Gas (BOG) from the cargo tanks at maximum flow rates.
The system comprises one vertical GCU with exhaust stack mounted on a new
generation of Liquefied Natural Gas (LNG) Carriers, to thermally oxidise excess
BOG (design composition 100% methane). The GCU is heated by means of an
up-fired single burner. Combustion air is supplied through the burner. Dilution
(cooling) air enters the oxidiser where it mixes with the products of combustion to
limit the exhaust stack flue gas exit temperature to atmosphere less than the
maximum allowable 535oC when the GCU is operating at its maximum design
conditions. Dilution air enters the GCU via a plenum room, this allows the air to
be distributed evenly when any 2 of the 3 fans are running.
The GCU is essentially a standby device to safely incinerate BOG in case of
failure of the Dual Fuel (DF) engines which normally consume all of the BOG. The
GCU is designed for quick start up and is able to reach full load from cold in only
a few minutes.
This file includes the manual for all the auxiliaries regarding the GCU includind modbus,
computers, bolts, fans, burner, all electronic equipment and detailed drawings for all the above.
Enjoy!
FULL LIST OF CONTENTS
VOLUME 1 = Sections 1 to 6 complete
SECTION 1 PROCESS DESIGN REQUIREMENTS
PARAGRAPH DESCRIPTION
1.1 SYSTEM DESCRIPTION
1.2 GCU START-UP
1.3 THERMAL OXIDISER
1.4 BURNER
1.5 EXHAUST GAS STACK
1.6 PERSONNEL PROTECTION SHIELD
1.7 GAS VALVE SYSTEM
1.8 GCU MAIN CONTROL PANEL
1.9 GCU COMBUSTION AND DILUTION AIR FAN SYSTEMS
1.10 GCU FUEL OIL PUMPING SYSTEM
SECTION 2 TECHNICAL DATA SHEETS/SCHEDULES
LIST OF TECHNICAL DATA SHEETS (DS) / SCHEDULES
ITEM DOCUMENT NO. TITLE
2.1 MA950020-404 GCU TECHNICAL DS
2.2 MA950020-401 COMBUSTION AIR FAN DS
2.3 MA950020-402 DILUTION AIR FAN DS
2.4 MA950020-411 COMBUSTION AIR FAN MOTOR DS
2.5 MA950020-412 DILUTION AIR FAN MOTOR DS
2.6 MA950020-302 VALVE SCHEDULE
2.7 MA950020-303 INSTRUMENT SCHEDULE
2.8 MA950020-309 EQUIPMENT SCHEDULE
2.9 MA950020-409 GCU BOLTING TIGHTENING
2.10 MA950020-405 GCU LUBRICATION OIL DS
2.11 AS-316 STORAGE, INSTALLATION & JOINING INSTRUCTIONS
FOR AO RATED MODULE FIRE SEALS
2.12 MA950020-432 THERMAL MOVEMENTS OF GCU & STACK DS
SECTION 3 OPERATION OF GAS COMBUSTION UNIT
3.1 GAS COMBUSTION UNIT (GCU) OPERATING MODES
3.2 OPERATION OF GAS COMBUSTION UNIT (GCU) – refer to Figure 3-1
3.3 IGNITION SYSTEMS
3.4 OPERATIONAL COMMENTS OF THE GCU
3.5 BASIC FAULT FINDING
3.5.1 PIPE TRAINS
3.5.2 COMBUSTION AIR (CA) AND DILUTION AIR (DA) FANS
3.5.3 DIESEL OIL PUMPS
3.5.4 FLAME SCANNERS
3.5.5 BURNER
3.5.6 OIL GUN
3.5.7 GAS POKERS AND GAS NOZZLES
3.5.8 AIR COOLED QUARL
SECTION 4 GCU CONTROL SYSTEM
LIST OF SPECIFICATIONS / DOCUMENTS / MANUALS
4.1 MA950020-800 FUNCTIONAL DESIGN SPECIFICATION (FDS)
4.2 MA950020-502 GCU CAUSE & EFFECT DIAGRAM
4.3 MA950020-807 GCU CONTROL PANEL – IAS DATA BITMAP
4.4 MA950020-811 GCU OPERATIONAL CONTROL MATRIX
SECTION 5 GAS COMBUSTION UNIT (GCU) MAINTENANCE
LIST OF SCHEDULES / INSTRUCTIONS
5.1 AS-421 PRESERVATION OF GCU EQUIPMENT & LAY-UP
MAINTENANCE SCHEDULE
5.2 AS-423 GCU FLOOR INSULATION, MAINTENANCE & RENEWAL
5.3 AS-430 GCU, WINDBOX & BURNER PAINT MAINTENANCE
5.4 AS-426 PROCEDURE FOR MAIN BODY INSPECTION AND REPAIR
SECTION 6 OPERATION AND MAINTENANCE OF BURNER
6.1 HEALTH AND SAFETY AT WORK ACT
6.2 SAFE OPERATION OF HAMWORTHY COMBUSTION EQUIPMENT
6.3 HAMWORTHY DUAL FUEL (DF) BURNER ASSEMBLY
6.4 GENERAL MAINTENANCE AND INSPECTION
6.5 ATOMISERS – GENERAL NOTES ON FITTING AND MAINTENANCE
6.6 DF AIR REGISTER GAS NOZZLES
6.7 BASIC FAULT FINDING
6.8 PREVENTATIVE MAINTENANCE SCHEDULE
LIST OF DRAWINGS
6.1 AS00-060 DUAL FUEL DF925 BURNER DISMANTLING PROCEDURE
SECTION 7 = Volume 2 Section 7 Complete.
PRINCIPAL SUPPLIERS EQUIPMENT – MECHANICAL AND INSTRUMENTATION
GAS COMBUSTION UNIT
7.1 COMBUSTION AIR FAN - MA950020-006
TAE-IL BLOWER MGF
DSME HN2289/90
7.1 a) Lubricant List See Section 2.10
7.1 b) Combustion Air Fan Drg.No MA950020-006 see Section 10.1
7.1 c) Maintenance Manuals Centrifugal Fan > HSHI HN S624/5/6/7
(35 sheets)
7.1 d) CA Fan Data Sheet
7.1 e) CA Fan Lifting Diagram
7.1 f) CA Fan Pneumatic Actuator & Positioner
7.1 g) CA Fan Vane control Drawing
FAN NO 1 FAN NO 2
TAG No TAG No
7.1.1 Centrifugal Fan * CA-FAN-113 CA-FAN-114
7.1.2 Temperature Winding Element CA-TE-113-R CA-TE-114-R
7.1.3 Temperature Winding Element CA-TE-113-S CA-TE-114-S
7.1.4 Temperature Winding Element CA-TE-113-T CA-TE-114-T
7.1.5 Inlet Vane Damper * CA-IVC-111 CA-IVC-112
7.1.6 Limit Switch - Position * CA-ZSI-111 CA-ZSI-112
7.1.7 Limit Switch - Low * CA-ZSL-111 CA-ZSL-112
7.1.8 Limit Switch - High * CA-ZSH-111 CA-ZSH-112
7.1.9 I/P Converter * CA-IP-111 CA-IP-112
7.1.10 Pneumatic Cylinder * CA-XV-111 CA-XV-112
7.1.11 Air Filter Regulator * CA-AFR-111 CA-AFR-112
Items * part of Item 7.1
7.1.12 Flexible Hose CA-FH-115 CA-FH-116
7.1.13 Temperature Transmitter CA-TT-115
HCE 630-WI-0019
7.1.14 Differential Pressure Transmitter CA-DPT-109
HCE 629-WI-0007
7.1.14 Air Flow Switch CA-FSLL-126 CA-FSLL-127
HCE 232-LL-0001
7.1.16 Flexible Hose CA-FH-128 CA-FH-129
HCE AS00-062
7.2 DILUTION AIR FAN - MA950020-007
TAE-IL BLOWER MGF
DSME HN 2289/90
7.2 a) Lubricant List See Section 2.10
7.2 b) Dilution Air Fan G.A.Drg.No MA950020-007 see Section 10.1
7.2 c) Maintenance Manuals IOM < Axial Fan >
HSHI HN S624/5/6/7 (18 sheets)
7.2 d) DA Fan Data Sheet
7.2 e) DA Fan Lifting Diagram
7.2 f) DA Fan Pneumatic Actuator & Solenoid Valve
FAN NO 1 FAN NO 2 FAN NO3
TAG No TAG No TAG No
7.2.1 Axial Fan * DA-FAN-102 DA-FAN-105 DA-FAN-120
7.2.2 Temp. Winding Element DA-TE-102-R DA-TE-105-R DA-TE-120-R
7.2.3 Temp. Winding Element DA-TE-102-S DA-TE-105-S DA-TE-120-S
7.2.4 Temp. Winding Element DA-TE-102-T DA-TE-105-T DA-TE-120-S
7.2.5 Shut off Damper * DA-SOD-101 DA-SOD-104 DA-SOD-123
7.2.6 Limit Switch - High * DA-ZSH-101 DA-ZSH-104 DA-ZSH-123
7.2.7 Limit Switch - Low * DA-ZSL-101 DA-ZSL-104 DA-ZSL-123
7.2.8 Solenoid Valve DA-SOV-101 DA-SOV-104 DA-SOV-123
7.2.9 Pneumatic Cylinder * DA-XV-101 DA-XV-104 DA-XV-123
7.2.10 Air Filter Regulator * DA-AFR-101 DA-AFR-104 DA-AFR-123
Items * part of Item 7.2
7.2.11 Flexible Hose DA-FH-103 DA-FH-106 DA-FH-122
7.2.12 Differential Pressure Transmitter DA-DPT-102
HCE 224-DW-0008
7.2.13 Temperature Transmitter EG-TT-107
HCE 630-WI-0006
7.2.14 Temperature Transmitter EG-TT-108
HCE 630-WI-0006
7.3 M.D.O. PUMPING SET MA950020-010 – See Section 10.1
TAG No TAG No
OIL PUMP #1 OIL PUMP #2
7.3.1 Ball Valve FO-HV-001 FO-HV-009
HCE 201-ST-0136
7.3.2 Y-Type Strainer FO-XX-002 FO-XX-010
HCE 026-14-0001
7.3.3 Pressure Gauge FO-PI-003 FO-PI-011
HCE 189-WI-0118
7.3.4 Diesel Oil Igniter Pump & Motor FO-PMP-004 FO-PMP-012
Assembly HCE AS00-054
7.3.4.1 Light Oil Pump FO-PMP-004 FO-PMP-012
HCE 237-SZ-0007
7.3.4.1a SUNTEC Oil Pump Type AN Gear Sizes 47-57-67-77-97 AN-11-Ed 12
7.3.4.2 Electric Induction Motor FO-PMP-004 FO-PMP-012
HCE 747116406
7.3.4.2a Brook Crompton Installation and Maintenance
AC electric induction motor 103-4EFD Issue 4
7.3.4.3 Pressure Relief Valve FO-PRV-017 FO-PRV-020
( integral to Pump assembly )
7.3.5 Non Return Valve FO-NRV-006 FO-NRV-013
HCE 201-CB-0008 FO-NRV-016 FO-NRV-019
7.3.6 Ball Valve FO-HV-007 FO-HV-014
HCE 201-ST-0136 FO-HV-015 FO-HV-018
7.3.7 Pressure Gauge FO-PI-008
HCE 189-WI-0119
7.3.10 2-Way Manifold VARIOUS
HCE 249-OL-0012
7.3.11 Swivel Adaptor VARIOUS
HCE 249-OL-0002
7.4 OIL & AIR VALVE PLATE MA950020-011 – See Section 10.1
Note: For specific information to items below refer to Section 7.8
FUEL OIL SERVICE
7.4.1 Ball Valve FO-HV-317
HCE 201-AO-0042
7.4.2 Y-Type Strainer FO-XX-303
HCE 201-GF-0003
7.4.3 Pressure Switch FO-PSLL-313
HCE 224-C6-0007
7.4.4 Solenoid Valve* FO-SV-318
HCE 201-CJ-0099
7.4.5 Solenoid Valve* FO-SV-319
HCE 201-CJ-0099
7.4.6 Non Return Valve FO-NRV-320
HCE 201-CB-0007
7.4.7 Pressure Reducing Valve FO-PCV-321
HCE 248-JO-0002
7.4.8 Pressure Gauge FO-PI-322
HCE 189-WI-0121
POWER / INSTRUMENT AIR SERVICE
7.4.9 Ball Valve IA-HV-301
HCE 201-AO-0044
7.4.10 Ball Valve IA-HV-309
HCE 201-AO-0041
7.4.11 Pressure Gauge IA-PI-302
HCE 189-WI-0120
7.4.12 Air Filter Regulator IA-AFR-305
HCE 248-PH-0006
7.4.13 Ball Valve IA-HV-304
HCE 201-AO-0044
7.4.14 Pressure Switch IA-PSLL-306
HCE 224-C6-0006
7.4.15 Pressure Gauge IA-PI-307
HCE 189-WI-0122
7.4.16 Ball Valve IA-HV-310
HCE 201-AO-0042
7.4.17 Solenoid Valve* IA-SV-315
HCE 201-CJ-0099
7.4.18 2-Way Manifold VARIOUS
HCE 249-OL-0012
7.4.19 Swivel Adaptor VARIOUS
HCE 249-OL-0002
7.4.20 Adaptor (fitted to *) VARIOUS
HCE 239-27-0001
7.5 GAS VALVE SKID MA950020-012 – See Section 10.1
BOIL OFF GAS SERVICE
7.5.1 Ball Valve BG-HV-201 BG-HV-225
HCE 201-BI-0024 BG-HV-227
7.5.2 Temperature Transmitter BG-TT-202
HCE 630-WI-0020
7.5.3 Temperature Gauge BG-TI-203
HCE 189-WI-0123
7.5.4 Temperature Transmitter BG-TT-204
HCE 630-WI-0020
7.5.5 Control Valve Assembly BG-FCV-206 BG-FCV-207
HCE 260-HF-0001
7.5.5a HÖGFORS VALVES Data Sheet Hogfors 465
Wafer Pattern V-Port Ball Valve Stainless Steel, 465, 46501 Series
05-05-2011
7.5.5b TYCO FLOW CONTROL
Keystone Figure 79 Pneumatic Actuator Operating and Maintenance Instructions and Fig 79 Pneumatic Actuator Data Sheet
HDLDS-0012-EN-0910
7.5.5c PMV VALVE CONTROL SYSTEM
Manual P5 /EP5 and EP5 Data Sheet 23740/2002.14
7.5.5d PMV VALVE CONTROL SYSTEM
Manual F5 and F5 Data Sheet FCD PMENIM0005-03/2008:1
7.5.5.1 Air Filter Regulator * BG-AFR-206
BG-AFR-207
7.5.5.2 I/P Converter * BG-IP-206
BG-IP-207
7.5.5.3 Position Transmitter * BG-ZT-206
BG-ZT-207
7.5.5.4 Limit Switch – Light Up * BG-ZSLU-206
BG-ZSLU-207
Items * part of Item 7.5.5
7.5.7 Pressure Transmitter HCE 629-WI-0006 BG-PT-208
7.5.8 Pressure Transmitter HCE 629-WI-0006 BG-PT-209
7.5.9 Ball Valve HCE 201-E2-0003 BG-XV-205
7.5.9.1 Solenoid Valve HCE 201-BK-0003 BG-SOV-205
7.5.9.2 Limit Switch HCE 185-EO-0003 BG-ZSL-205
7.5.9.3 Limit Switch HCE 185-EO-0003 BG-ZSH-205
7.5.9.4 Pneumatic Actuator HCE 185-CJ-0006 BG-XV-205
7.5.10 Ball Valve HCE 201-BI-0026 BG-XV-211
7.5.10.1 Solenoid Valve HCE 201-BK-0003 BG-SOV-211
7.5.10.2 Limit Switch HCE 185-EO-0003 BG-ZSL-211
7.5.10.3 Pneumatic Actuator HCE 185-CJ-0007 BG-XV-211
7.5.11 Ball Valve HCE 201-E2-0003 BG-XV-212
7.5.11.1 Solenoid Valve HCE 201-BK-0003 BG-SOV-212
7.5.11.2 Limit Switch HCE 185-EO-0003 BG-ZSL-212
7.5.11.3 Limit Switch HCE 185-EO-0003 BG-ZSH-212
7.5.11.4 Pneumatic Actuator HCE 185-CJ-0006 BG-XV-212
7.5.12 Ball Valve HCE 201-BI-0026 BG-XV-213
7.5.12.1 Solenoid Valve HCE 201-BK-0003 BG-SOV-213
7.5.12.2 Limit Switch HCE 185-EO-0003 BG-ZSL-213
7.5.12.3 Pneumatic Actuator HCE 185-CJ-0007 BG-XV-213
7.5.13 Flame Arrestor HCE 199-00-0008 BG-BX-221
7.5.14 Ball Valve HCE 201-BI-0225 BG-HV-224
BG-HV-226
7.5.14.1 Limit Switch HCE 185-EO-0003 BG-ZSL-224
BG-ZSL-226
POWER/INSTRUMENT AIR SERVICE
7.5.15 Ball Valve HCE 201-AO-0043 IA-HV-323
7.5.16 Ball Valve HCE 201-AO-0044 IA-HV-308
PURGE NITROGEN SERVICE
7.5.17 Ball Valve HCE 201-AO-0044 PN-HV-214
7.5.18 Pressure Gauge HCE 189-WI-0125 PN-PI-215
7.5.19 Pressure Switch HCE 224-C6-0005 PN-PSLL-216
7.5.20 Ball Valve HCE 201-AO-0045 PN-XV-217
7.5.20.1 Solenoid Valve HCE 201-BK-0003 PN-SOV-217
7.5.20.2 Limit Switch HCE 185-EO-0003 PN-ZSL-217
7.5.20.3 Limit Switch HCE 185-EO-0003 PN-ZSH-217
7.5.20.4 Pneumatic Actuator HCE 185-CJ-0005 PN-XV-217
7.5.21 Non Return Valve HCE 201-CB-0004 PN-NRV-218
7.5.22 Ball Valve HCE 201-AO-0042 PN-HV-229
7.5.23 Non Return Valve HCE 201-CB-0007 PN-NRV-230
7.5.24 2-Way Manifold HCE 249-OL-0012 VARIOUS
7.5.25 Swivel Adaptor HCE 249-OL-0002 VARIOUS
7.5.26 10 Way Instrument Air Manifold HCE 201-HN-0003
7.5.27 Flow Meter HCE 207-FG-0002 BG-FM-231
7.5.28 Cooling Tower HCE 239-WI-0001
BURNER SERVICES MA950020-002 I See Section 10.1
7.6.1 Flexible Hose HCE 186-AF-0523 BG-FH-228
7.6.2 Flexible Hose HCE 186-AF-0526 FO-FH-327
7.6.3 Flexible Hose HCE 186-AF-0527 IA-FH-326
7.6.4 Non return Valve HCE 201-H1-0002 IA-NRV-316
7.6.5 Non return Valve HCE 201-H1-0002 IA-NRV-329
7.6.6 UV-VIS Head (Safe Area) HCE 363920828/P BF-BE-001
7.6.7 Cable Assembly HCE 363920637 BF-BE-001
7.6.8 UV-VIS Head (Safe Area) HCE 363920828/P BF-BE-002
7.6.9 Cable Assembly HCE 363920637 BF-BE-002
7.6.10 Igniter Arrangement BF-IGN-117
7.6.10.1 HE Igniter HCE 184-CH-0144 BF-IGN-117
7.6.10.2 Exciter HCE 184-CH-0205 BF-IGN-117
7.6.10.3 Cable HCE 184-CH-0206 BF-IGN-117
7.6.10.4 Extension Rod HCE 184-CH-0207 BF-IGN-117
7.6.11 Pneumatic Cylinder HCE 183-IL-0001 IA-XV-115
7.6.12 Exhaust Flow Reg/Silencer HCE 248-IL-0001 IA-SCV-115
7.6.13 Exhaust Flow Reg/Silencer HCE 248-IL-0001 IA-SCV-115
7.6.14 Solenoid Valve arrangement IA-SOV-115
7.6.14.1 Solenoid Valve HCE 201-IL-0001 IA-SOV-115
7.6.14.2 24V Coil HCE 238-IL-0001 IA-SOV-115
7.6.15 Limit Switch arrangement IA-ZSH-115
7.6.15.1 Limit Switch HCE 232-TQ-0007 IA-ZSH-115
7.6.15.2 Roller Plunger Head HCE 232-TQ-0004 IA-ZSH-115
7.6.16 as 7.6.15.1.& 7.6.15.2 above IA-ZSL-115
7.6.17 Igniter Arrangement BF-IGN-118
7.6.17.1 HE Igniter HCE 184-CH-0144 BF-IGN-118
7.6.17.2 Exciter HCE 184-CH-0205 BF-IGN-118
7.6.17.3 Cable HCE 184-CH-0206 BF-IGN-118
7.6.17.4 Extension Rod HCE 184-CH-0207 BF-IGN-118
7.6.18 Pneumatic Cylinder HCE 183-IL-0001 IA-XV-116
7.6.19 Exhaust Flow Reg/Silencer HCE 248-IL-0001 IA-SCV-116
7.6.20 Exhaust Flow Reg/Silencer HCE 248-IL-0001 IA-SCV-116
7.6.21 as 7.6.14.1 & 7.6.14.2 above IA-SOV-116
7.6.22 as 7.6.15 above IA-ZSH-116
7.6.23 as 7.6.16.above IA-ZSL-116
OIL BURNER AIR FAN ASSEMBLIES
OIL BURNER OIL BURNER
AIR FAN #1 AIR FAN #2
7.7.1 Backward Inclined Fan CA-FAN-119 CA-FAN-121
HCE 233-HL-0022
7.7.1a) Installation, Operation and Maintenance Instructions
Halifax Fan Limited
7.7.1b) Machine Instructions – Induction motor
(English language version only)
ABB Motors
7.7.2 Flexible Hose CA-FH-119 CA-FH-121
HCE 186-FH-0024
7.7.3 Butterfly Valve CA-HV-119 CA-HV-121
HCE 201-EW-0001
7.7.4 Ball Valve CA-HV-125
HCE 201-AO-0041
7.7.5 Pressure Gauge CA-PI-119
HCE 189-WI-0145
7.7.6 Pressure Switch CA-PSLL-119
HCE 224-C6-0004
EQUIPMENT GROUPS
7.8 VALVES
HCE PART NO. TAG NO.
7.8.1 NON-RETURN VALVE HCE 201-CB-0008 FO-NRV-006
HCE 201-CB-0008 FO-NRV-013
HCE 201-CB-0008 FO-NRV-019
7.8.1a Installation, operation and maintenance instructions
Gate, globe, check and ball valves Doc. DT01-05e-B Edition 2005
Revision B LVF Forged Steel Valves
7.8.2 NON-RETURN VALVE HCE 201-CB-0007 FO-NRV-320
7.8.2a Installation, Operation and Maintenance Manual Doc. No TP 20
Rev 002 21 Nov.2006 CALOBRI
7.8.3 Non Applicable
7.8.4 NON-RETURN VALVE HCE 201-H1-0002 IA-NRV-316
7.8.4a HY-LOK 700 Series Catalog No. H-700CV Oct.2003
7.8.5 BALL VALVE HCE 201-AO-0041 CA-HV-125
HCE 201-AO-0042 FO-HV-317
HCE 201-AO-0044 IA-HV-301
HCE 201-AO-0044 IA-HV-304
HCE 201-AO-0041 IA-HV-309
HCE 201-AO-0042 IA-HV-310
7.8.5a Three Piece Ball Valve User Manual (Operating & Maintenance Instructions) Document No SM23 Date 2004/11/5 Version 1.0
Anson Flow
7.8.6 BALL VALVE HCE 201-ST-0136 FO-HV-001
HCE 201-ST-0136 FO-HV-007
HCE 201-ST-0136 FO-HV-009
HCE 201-ST-0136 FO-HV-014
HCE 201-ST-0136 FO-HV-018
7.8.6a INSTRUCTION MANUAL Storage, installation, use and handling of Starline ball valves Manual no: 124-CE STARLINE
7.8.7 BALL VALVE ASSY HCE 201-BI-0024 BG-HV-201
7.8.7a BAC Valves, Installation and Maintenance Instructions PQR-i I-19-701-G
7.8.8 BALL VALVE ASSY HCE 201-E2-0003 BG-XV-205
7.8.8a Installation, Operation & Maintenance Instruction 2-Pce, flanged end,
Ball valves Fig. 7245, 7249, 7257, 7285, 7289, 7297 ECONOSTO
7.8.8b Installation, Operation & Maintenance Instruction (Flanged End Ball Valves) ECONOSTO 200302(01)
7.8.9 CONTROL VALVE ASSY BG-FCV-206 BG-FCV-207
HCE 260-HF-0001
7.8.9a HOGFER DATA SHEETS
Wafer Pattern V-port Ball Valves Data Sheet Hogfors 465 – See Section 7.5.5a
Wafer Pattern V-Port Ball Valve Stainless Steel, 465, 46501 Series 05-05-2011
7.8.9c TYCO FLOW CONTROL
and Fig 79 Pneumatic Actuator Data Sheet – See Section 7.5.5b
HDLDS-0012-EN-0910
7.8.9d PMV VALVE CONTROL SYSTEM
Manual P5 / EP5 Data Sheet 23740/2002.14 – See Section 7.5.5c
7.8.9e PMV VALVE CONTROL SYSTEM
Manual F5 Data Sheet FCD PMENIM0005-03/2008:1 - See Section 7.5.5d
7.8.10 PRESSURE REDUCING VALVE FO-PCV-321
HCE 248-JO-0002
7.8.10a JORDAN VALVE JPR Data Sheet
7.8.11 BUTTERFLY VALVE CA-HV-119 CA-HV-121
HCE 201-EW-0001
7.8.11a Wafer Pattern Butterfly Type Technical Data Z011-
7.8.11b BA 1.1:Operating Instruction Valve series rubber lined,with lever/handwheel
Rev.0307.02
EBRO – ARMATUREN
7.8.12 SOLENOID VALVE HCE 201-CJ-0099 FO-SV-318
HCE 201-CJ-0099 FO-SV-319
HCE 201-CJ-0099 IA-SV-315
7.8.12a Installation & Maintenance – 2 Way Normally Closed L67/AP.p, Red Dragon Valves
7.8.13 SOLENOID VALVE HCE 201-BK-0003 BG-SOV-205
7.8.13a Installation and Operating Instructions 6517/6519 BURKERT
7.8.14 SOLENOID VALVE TAE-IL DA-SOV-101
TAE-IL DA-SOV-104
TAE-IL DA-SOV-123
7.9 ACTUATORS
7.9.1 PNEUMATIC ACTUATOR Part of HCE 260-HF-0001 BG-FCV-206
BG-FCV-207
7.9.1a TYCO FLOW CONTROL
See Section 7.5.5c also
7.9.2 PNEUMATIC ACTUATOR FAN NO 1 CA-XV-111
CA Inlet Vane Damper FAN NO 2 CA-XV-112
7.9.2a CA Fan Pneumatic Actuator & Positioner
7.9.3 PNEUMATIC ACTUATOR FAN NO 1 DA-XV-101
DA Inlet Vane Damper FAN NO 2 DA-XV-104
FAN NO 3 DA-XV-123
7.9.3a DA Fan Pneumatic Actuator & Solenoid Valve
7.9.4 PNEUMATIC ACTUATOR HCE 185-CJ-0006 BG-XV-205
7.9.4a INSTALLATION, SAFETY & MAINTENANCE INSTRUCTIONS
ATEX-INS(i) Rev.0 14/03/05 QUIFFER ACTUATORS SL.
EQUIPMENT GROUPS
7.10 LIMIT SWITCH
7.10.1 LIMIT SWITCH HCE 185-EO-0003 BG-ZSH-205
7.10.1a CV32D Product Manual Cotswold Valves Ltd
7.10.2 LIMIT SWITCH Part of BG-FCV-206 BG-ZSLU-206
Part of BG-FCV-207 BG-ZSLU-207
7.10.3 LIMIT SWITCH TAE-IL CA-ZSH-111
CA Supply Damper TAE-IL CA-ZSH-112
TAE-IL CA-ZSI-111
TAE-IL CA-ZSI-112
TAE-IL CA-ZSL-111
TAE-IL CA-ZSL-112
7.10.3a See Section 7.1
7.10.4 LIMIT SWITCH TAE-IL DA-ZSH-101
DA Supply Damper TAE-IL DA-ZSH-104
TAE-IL DA-ZSH-123
TAE-IL DA-ZSL-101
TAE-IL DA-ZSL-104
TAE-IL DA-ZSL-123
7.10.4a See Section 7.2
7.10.5 LIMIT SWITCH HCE 232-TQ-0007 IA-ZSH-115
Main Flame HE Igniter HCE 232-TQ-0007 IA-ZSH-116
HCE 232-TQ-0007 IA-ZSL-115
HCE 232-TQ-0007 IA-ZSL-116
EQUIPMENT GROUPS
7.11 STRAINERS, FILTERS AND REGULATORS PLUS FLEXIBLE HOSES
AND DECK SEALS
7.11.1 AIR FILTER /REGULATOR HCE 248-PH-0006 IA-AFR-305
7.11.1a Filter/Regulator “Piggybacks” Air preparation Units
Catalog 0700P-2/USA (Revised 12/10/04) Parker Hannifin Corp.
7.11.1b Safety Guide Pneumatic Products Parker Hannifin Corp.
Catalog 0700P-4/USA
PART OF 7.5.5 BG-AFR-206
BG-AFR-207
TAE-IL CA-AFR-111
TAE-IL CA-AFR-112
TAE-IL DA-AFR-101
TAE-IL DA-AFR-104
TAE-IL DA-AFR-123
7.11.2 Y-TYPE STRAINER HCE 201-GF-0003 FO-XX-303
7.11.2a Installation,Operating and Maintenance Instructions
“Y” Type Strainers Kaysafe Engineering Limited
7.11.3 Y-TYPE STRAINER HCE 026-14-0001 FO-XX-002
HCE 026-14-0001 FO-XX-010
7.11.3a Installation, Operating and Maintenance Manual for Y-Type Strainers
Document No: N4202-01 Rev01 08-03-10 GFSA
7.11.3 FLEXIBLE HOSE HCE 186-AF-0523 BG-FH-228
7.11.4 FLEXIBLE HOSE TAE-IL CA-FH-115
7.11.5 FLEXIBLE HOSE TAE-IL CA-FH-119
7.11.7 FLEXIBLE HOSE HCE 186-IT-0050 CA-FH-121
7.11.8 FLEXIBLE HOSE HCE AS00-062 CA-FH-128
7.11.9 FLEXIBLE HOSE HCE AS00-062 CA-FH-129
7.11.10 FLEXIBLE HOSE TAE-IL DA-FH-103
7.11.11 FLEXIBLE HOSE TAE-IL DA-FH-106
7.11.12 FLEXIBLE HOSE TAE-IL DA-FH-122
7.11.14 FLEXIBLE HOSE HCE 186-AF-0526 FO-FH-327
7.11.15 FLEXIBLE HOSE HCE 186-AF-0527 IA-FH-326
7.11.16 GCU TOP SEAL HCE 178-KK-0008
GCU LOWER SEAL HCE 178-KK-0009
7.11.16a Storage, Handling & Installation, Operating & Maintenance Instructions AS-316
EQUIPMENT GROUPS
7.12 FLAME ARRESTOR HCE 199-00-0008 BG-BX-221
7.12a ‘’SFG’’TYPE General Assembly Drawing SFG-0150-12F-371-01
7.12b User Instruction Manual Model – SFG 2K508-SFG-EN-R1
SEWON FLAME ARRESTERS (DEFLAGRATION FLAME ARRESTERS)
EQUIPMENT GROUPS
7.13 PRESSURE GAUGES, SWITCHES AND TRANSMITTERS
7.13.1 PRESSURE GAUGE HCE 189-WI-0124 BG-PI-210
HCE 189-WI-0145* CA-PI-119
HCE 189-WI-0118 FO-PI-003
HCE 189-WI-0118 FO-PI-011
HCE 189-WI-0119 FO-PI-008
HCE 189-WI-0121 FO-PI-322
HCE 189-WI-0120 IA-PI-302
HCE 189-WI-0122 IA-PI-307
7.13.1a Bourdon Tube Pressure Gauges Stainless Steel Series
Model 232.50/233.50, without/with Liquid Filling
WIKA Data Sheet PM 02.02 – 04/2008
7.13.1b Pressure Gauges Operating Instructions
2408976.03 02/2010
7.13.1b Capsule Pressure Gauges Stainless Steel Series
Model 632.50/633.50, without/with Liquid Filling
WIKA Data Sheet PM 06.03 – 12/2008 *Refers to CA-PI-119 only
7.13.2 PRESSURE SWITCH HCE 224-C6-0004* CA-PSLL-119
HCE 224-C6-0007 FO-PSLL-313
HCE 224-C6-0006 IA-PSLL-306
HCE 244-C6-0005 PN-PSLL-216
7.13.2a Compact Press. Switches Series PCS & PCA Instruction Manual
Cella NI-281E Rev.7 11/07
7.13.2b Diaphragm Pressure Switches Instruction Manual
Cella NI-221E Rev.2 11/07
7.13.2C Modular Pressure Switches Weatherproof execution – Low pressure
Series MWB Cella PT-B1-12 Rev4 04-07 *Refers to CA-PSLL-119 only
7.13.3 PRESSURE HCE 629-WI-0006* BG-PT-208
TRANSMITTER HCE 629-WI-0006* BG-PT-209
HCE 629-WI-0007** CA-DPT-109
7.13.3a Intrinsically Safe Pressure Transmitter for applications in hazardous
environments Models IS-20-S, IS-21-S, IS-20-F, IS-21-F
Data Sheet PE 81.50 - 11/2007
WIKA * Refers to BG-PT-208 and BG-PT-209 only
7.13.3b Differential Pressure Transmitter with Diaphragm, Pressure rating
PN 2.5/25/40 bar Standard – Model 891.34.1998 PE 81.70
WIKA ** Refers to CA-DPT-109 only
7.13.3c Operating Instructions for Pressure Transmitters
12.01 S-Nr. 2058 464 WIKA ** Refers to CA-DPT-109 only
7.13.3d Safety-Related Data – Additional Instructions
7.13.4 DIFFERENTIAL HCE 629-WI-0008 DA-DPT-102
PRESSURE TRANSMITTER
7.13.4a Wika Model 891.34.1998 PE 81.70
EQUIPMENT GROUPS
7.14 TEMPERATURE GAUGES AND TRANSMITTERS
7.14.1 TEMPERATURE GAUGE HCE 189-WI-0123 BG-TI-203
7.14.1a Bimetal Thermometers – Process Industry Series, Model 55
WIKA Data Sheet TM55.01 – 03/2009
7.14.2 TEMPERATURE HCE 630-WI-0020 BG-TT-202
TRANSMITTER HCE 630-WI-0020 BG-TT-204
HCE 630-WI-0019 CA-TT-115
HCE 630-WI-0006 EG-TT-107
HCE 630-WI-0006 EG-TT-108
7.14.2a Resistance Thermometers Model TR10-B, for Additional
Thermowell WIKA Data Sheet TE60.02 – 03/2011
7.14.2b Analogue Temperature Transmitters For Pt 100 Sensors,
PC –configurable, Head Mounting Model T24.10
WIKA Data Sheet TE24.01 – 04/2010
Note: 7.14.2a & 7.14.2b for BG-TT-202, BG-TT-204 & CA-TT-115
7.14.2c Digital temperature transmitters Model T12.10, universally
programmable, head mounting version
WIKA Data Sheet TE12.03 – 06/2010
7.14.2d TC15 Remote Mount Industrial Thermocouple Assembly
WIKA Brochure TC15
Note: 7.14.2c & 7.14.2d for EG-TT-106 & EG-TT-107
7.14.2e Bimetal Thermometer, Models 53, 54, 55 – Operating Instructions
12968065.03 09/2010
7.14.2f Resistance Thermometers and Thermocouples – Operating Instructions
11208287.03 06/2010
7.14.2g Resistance Thermometers and Thermocouples (ATEX) – Operating Instructions
3227278.03 07/2011
EQUIPMENT GROUPS
7.15 IGNITERS
7.15.1 HIGH ENERGY (HE) SPARK IGNITERS
7.15.1.1 HE Igniter HCE 184-CH-0144 BF-IGN-117 BF-IGN-118
7.15.1.2 Exciter HCE 184-CH-0205 BF-IGN-117 BF-IGN-118
7.15.1.3 Harness HCE 184-CH-0206 BF-IGN-117 BF-IGN 118
7.15.1.4 Extension Rod HCE 184-CH-0207 BF-IGN-117 BF-IGN-118
7.15.1a OPERATIONS & MAINTENANCE MANUAL
SmartSpark® High Energy Ignition System
Smart Spark PN 070000224 MANUAL Rev D 16MAR10
Note:Igniter assembled on site.Igniter Tip HCE 184-CH-0144 is a consumable.
EQUIPMENT GROUPS
7.16 UV-VIS Head (Safe Area) 363920828/P BF-BE-001
7.16a SMARTSCAN ® 121 Flame Scanning System 3439017/040 15-10-00
Issue 2.5 Dated 09-04-09 Hamworthy Combustion Engineering Ltd.
EQUIPMENT GROUPS - MISC
7.17 INSTRUMENT MANIFOLDS & AIR FLOW SWITCH
7.17.1 2 VALVE MANIFOLD HCE 249-OL-0012
7.17.1a Product Data Sheet G12AF Type 2 Valve Manifold Rev 1.0
Oliver Valves Limited
7.17.1b DWG No. A3256 Issue E
7.17.2 10 VALVE MANIFOLD HCE 201-HN-0003
7.17.2a Data Sheet TD900MBV/D 01.07
7.17.2b Series 910 Minifold Dimensioned Outline Drawing M910-001-F
HNL ENGINEERING LTD.
7.17.3 SWIVEL MOUNT HCE 249-OL-0002
7.17.3a Product Data Sheet GAH50S Type Swivel Gauge Adaptor Rev 1.2
7.17.4 AIR FLOW SWITCH HCE 232-LL-0001 CA-FSLL-126
HCE 232-LL-0001 CA-FSLL-127
7.17.4a AIR FLOW CONTROLLER – Compact model Series LN
EGE - Technical Data
VOLUME 3 = Section 8 Part 1 – 8.1 to 8.1.2.3 VOL 4 = Section 8 Part 2 8.1.2.4 to 8.3
SECTION 8 PRINCIPAL SUPPLIERS EQUIPMENT – CONTROL
LIST OF SPECIFICATIONS / CERTIFICATES / MANUALS ETC
CONTROL PANEL MA950020-500
HAMWORTHY COMBUSTION ENGINEERING LIMITED
8.1.1 ENCLOSURE AND ASSOCIATED ITEMS
a) Technical documentation – Assembly Guide TS8 – Rittal
b) Plinth – Assembly Instructions TS8 – Rittal
c) De luxe handle – Assembly Instructions TS8 – Rittal
d) Fan and filter units – Assembly Instructions SK – Rittal
e) Enclosure thermostat – Assembly Instructions SK – Rittal
8.1.2 CONTROL MODULES - ALLEN BRADLEY
8.1.2a ControlLogix Controller User Manual
Publication 1756-UM0011H-EN-P July 2008
8.1.2.1 ControlLogix PLC Rack – 17 slot and 10 slot
1756-A17 Series B and 1756-A10 Series B
8.1.2.1a ControlLogix Chassis-Series B -Installation Instructions Publication 1756-IN080C-EN-P
December 2003
8.1.2.2 ControlLogix Processor 1756-L61 2Mb Series B
8.1.2.2a ControlLogix Controller and Memory Board – Installation Instructions Publication
1756-IN101L-EN-P June 2008
8.1.2.3 ControlLogix Redundancy Module 1756-RM Series B
8.1.2.3a ControlLogix Enhanced Redundancy System - Installation
Instructions Publication 1756-UM535D-EN-P Nov 2012
8.1.2.4 ControlLogix Analogue Output Module 1756-OF8 Series A
8.1.2.4a ControlLogix Voltage/Current Output Module – Installation Instructions Publication
1756-IN015B-EN-P February 2003
8.1.2.4b ControlLogix Analog I/O Modules – User Manual
Publication 1756-UM009B-EN-P June 2003
8.1.2.5 ControlLogix Digital Input Module 1756-IB16D Series A
8.1.2.5a ControlLogix DC (10-30V) Diagnostic Module – Installation Instructions Publication
1756-IN069C-EN-P October 2000
8.1.2.6 ControlLogix Digital Output Module 1756-OB16D Series A
8.1.2.6a ControlLogix DC (19.2-30V) Diagnostic Output Module – Installation Instructions
Publication 1756-IN058D-EN-P October 2000
8.1.2.7 ControlLogix Controlnet Interface Module 1756-CN2 Series B
8.1.2.7a ControlLogix ControlNet Interface Module – Installation Instructions Publication
1756-IN607-EN-P February 2008
8.1.2.7b ControlLogix ControlNet Interface Module – Release Notes Publication
1756-RN650E-EN-E November 2012
8.1.2.8 ControlLogix Ethernet Bridge 1756-EN2T
8.1.2.8a ControlLogix EtherNet/IP Bridge Module – Installation Instructions Publication
1756-IN603C-EN-P April 2010
8.1.2.9 ControlLogix AC Isolated Contact Module 1756-OW16l
8.1.2.9a ControlLogix AC (10-265V) DC (5-150V) Isolated Contact Module Installation
Instructions Publication 1756-IN011B-EN-P February 2003
8.1.2.10 ControlNet Coax Tap 1786-TPS
8.1.2.10aControlNet Coax Taps – Installation Instructions
1786-IN007B-EN-P June 2006
8.1.2b CSA Hazardous Location Approval Publication AG-4.1
February 2000
8.1.2c End User License Agreement (“EULA”)
Publication VIEW-PC001C-EN-P 41061-185-01(3)
8.1.3 2711P-RDT10CM PanelView Plus 1000 Series
8.1.3.1 2711P-RP8AM AC Logic Module
8.1.3a PanelView Plus 6 Installation Instructions
Publication 2711P-IN029A-EN-P November 2010
8.1.4 POWER SUPPLIES
8.1.4.1 ControlLogix Rack PSU (24V DC) 1756-PB75/B Series B
8.1.4.1a ControlLogix Power Supplies – Installation Instructions Publication 1756-IN613A-EN-P December 2008
8.1.4.2 1606-XL Power Supply Technical Data 1606-XL480E
8.1.4.3 1606-XL Power Supply Technical Data 1606-XLRED20-30
8.1.4.4 1606-XL Power Supplies DIN-Rail Power Supplies Installation and Operation
8.1.4a Guidelines for Handling Lithium Batteries – Technical Data Publication
AG-5.4 (AG-TD054D-EN-P) November 2004
8.1.5 ISOLATING BARRIERS
8.1.5.1 STAHL9160 Transmitter Supply Unit – Operating Instructions
8.1.5.2 STAHL9165 Isolating Repeater Output – Operating Instructions
8.1.5.3 STAHL9170 Switching Repeater – Operating Instructions
8.1.5.4 STAHL9175 Digital Output – Operating instructions
8.1.6 MV156E-MCM Modbus Communications Module
8.1.6a MVI56E-MCM ControlLogix Platform Modbus Communications
Module – Data Sheet – November 2010
8.1.6b MV156E-MCM Controllogix Platform Modbus Communications
Module Set up Guide – April 2011
8.1.7 SIXNET ET-5ES-1
8.1.7a EtherTrak Industrial Ethernet Unmanaged Switches
Sixnet User Manual – last revised 26-Sept-08
8.1.8 ISOLATION MODULE 4-20mA 5104A-B2B
8.1.8a PR ELECTRONICS 5104 Repeater/Power Supply Manual
8.2 MOTOR STARTER CONTROL PANELS
8.2.1 No1 & No2 FUEL OIL PUMP MOTOR STARTER CONTROL
PANEL GROUP ASSEMBLY MA950020-515
8.2.1.1 FUEL OIL PUMP MOTOR STARTER CONTROL PANEL
(0.25 kW) MA950020-512
8.2.2 COMBUSTION AIR FAN MOTOR STARTER CONTROL
PANEL (210 kW) MA950020-510
8.2.3 DILUTION AIR FAN MOTOR STARTER CONTROL PANEL
(190 kW) MA950020-511
8.2.4 LOCAL MOTOR PUSHBUTTON CONTROL STATION
MA950020-516
8.2.5 No.1 & No.2 OIL BURNER AIR FAN MOTOR STARTER CONTROL PANEL GROUP
ASSEMBLY MA950020-531
8.2.5.1 OIL BURNER AIR FAN MOTOR STARTER CONTROL PANEL
(0.75 kW) MA950020-522
8.3 KEUNYOUNG TECH – MOTOR STARTER PANEL ASSEMBLY
8.3a INSTRUCTION MANUAL FOR STARTER (22 sheets)
VOLUME 5
SECTION 9 SPARE PARTS
LIST OF PARTS / SPECIAL TOOLS ETC
9.1 MA950020-313 SPARE PARTS AND SPECIAL TOOLS LIST
SECTION 10 DRAWINGS
Section 10.1 – Mechanical Drawings
Drawing Number Description
MA950020-001 P & ID for Gas Combustion Unit
MA950020-002 P & ID for Burner Services
MA950020-003 Gas Combustion Unit Layout
MA950020-004 GA Gas Combustion Unit
MA950020-005 DF1105 Dual Fuel Burner GA
MA950020-006 Combustion Air Fan G.A.
MA950020-007 G.A. of Dilution Air Fan
MA950020-010 M.D.O. Pumping Set
MA950020-011 Oil & Air Valve Plate
MA950020-012 Gas Valve Skid
MA950020-016 Installation of GCU on Foundation Foot Stools
AS00-085 JIS Boil-Off Gas Inlet Split Casing Flexible Connection Arrangement
MA950020-703 GCU Top Mating Flanges
MA950020-704 Windbox Fittings
AS00-086 N19 & N20 Nozzle details Exhaust Gas Temperature
Transmitter Hook-up Diagram
MA950020-718 GCU to Deck Sealing Details and Fittings
AS00-006 G.A. Oil Pilot Combustion Air Fan
AS00-042-08 Sample Connection Port N21 & N22
AS00-060 Dual Fuel DF925 Burner Dismantling Procedure
Section 10.2 – Control / Electrical Drawings
MA950020-500 GCU Control System – Control Panel – Outline Drawing
MA950020-501 GCU Control System – Control Panel – General Arrangement
MA950020-502 GCU Cause & Effect Diagram
MA950020-503 Analogue Control Scheme
MA950020-504 Sequence Control Overview Flow Diagram
MA950020-505 GCU Control System Overview Diagram
MA950020-508 GCU Control Panel Terminal Rail Layout
MA950020-509 GCU Control System Single Line Block Cable Drawing
MA950020-510 Combustion Air Fan Motor Starter Control Panel (210 kW)
MA950020-511 Dilution Air Fan Motor Starter Control Panel (190 kW)
MA950020-512 Fuel Oil Pump Motor Starter Control Panel (0.25 kW)
MA950020-513 PLC Architecture Diagram
MA950020-514 Combustion and Dilution Air Fan Motor Starter Control Panel Group Assembly
MA950020-515 No.1 & No.2 Fuel Oil Pump Motor Starter Control
MA950020-516 Local Motor Pushbutton Control Station
MA950020-518 GCU Control System Control Panel Schematic
MA950020-519 GCU Control System External Wiring Schematic
MA950020-522 Oil Burner Air Fan Motor Starter Control Panel (0.75 kW)
MA950020-531 No.1 & No.2 Oil Burner Air Fan Motor Starter Control
GAS COMBUSTION UNIT
Download [26 KB]
The time now is: Today 16:50
