dsutra ®   26-Jun-2022 05:37
Mooring - Do It Safely
Year: 2013
Author: Seahealth Denmark
Publisher: Seahealth Denmark
ISBN: 978-87-92084-28-6
Pages count: 88
Description: Mooring, towing and hauling impose enormous strains on lines, warps, gear and equipment and major forces are involved. Therefore – take care and think carefully when mooring – especially on ships with structures that make it hard to oversee what is happening. Also on ships calling at different ports the specific mooring arrangements may differ considerably.
As humans we tend to believe that things are safe if nothing happens. You might say that the norm for what we believe is dangerous decreases over time. Normally mooring goes well, but as time goes by, the level of safety slowly declines. Maybe you lose concentration, maybe you slacken your procedures just a little bit, maybe you get a little complacent. And then it suddenly happens – not because of one factor but because of a number of interacting factors.
Factors can be found in:
• Equipment
• Work processes
• Crew qualifications
• Crew concentration
• Ship’s safety culture
• Weather
Preventing accidents is about reducing the risks of those factors. The only parameter that is hard to overcome in this respect is the weather.
Mooring_Do_It_Safely.pdf
dsutra ®   27-Jun-2022 08:30
Thanks for the update. Strange that the title didn't show up when I was adding it.
gillnumil   27-Jun-2022 09:26
dsutra, Don't just rely on the auto search which happens when you are typing the title for the new release.
Rule 8.1: Before release creation, check that there is no the same release on the tracker uploaded (use the search or enter the title in the release creation form).
It is the duty of the releaser to check and verify that the book is not already present. Search is much improved now.
1) Do a manual search for the title (Less words & key words...avoid punctuations and hyphens etc.) e.g. Mooring alone would be sufficient. You can add more words to filter the search.
2) Google search within the tracker. Avoid copy pasting the title and write manually without punctuations.
Pls chk out below pics.
The Oilfield Seamanship Series: Volume 5 | Barge Moving - Michael Hancox [2011, PDF]
Mooring - Do it safely - Soren Boge Pedersen [2013, PDF]
MSC Circ.1175 Guidance on Shipboard Towing and Mooring Equipment - IMO Circular [2005, PDF]
HYGIENE IN THE GALLEY - good advice for self-assessment aboard - Seahealth Denmark [2012, PDF]
Deck Stowage and Securing of Pipes - C.Bliault [2008, PDF]
Chemicals - Take Care of Yourself and Others - Seahealth Denmark [2012, PDF]
OCIMF Mooring Equipment Guidelines - OCIMF [1997, PDF]
The Pocket Book of Anchoring - Captain Michael Lloyd FNI [2011, PDF]
Shipping and Rest - How We Can Do Better - C.Gehrt [2010, PDF]
Effective Mooring [PDF]
The time now is: Today 10:17
