Echologic1 ®   05-Mar-2022 15:56
Kongsberg SP Dual Fuel Simulator
Year: 2009
Version: 2.4.0.0259
Developer: Kongsberg
64-bit OS compatibility: yes
Crack: Included
Description: Simulator for steam propulsion plant. 2 main boilers on MDO/HFO/BOG. Main propulsion steam turbine. Turbo pumps, etc.
Additionally: After normal installation from unzipped folder, use .exe file from zipped folder (copy to the installed directory). Shall be fine then.
SP Dual Fuel Simulator - 2.4.0.0259.zip
Download [19 KB]
Echologic1 ®   05-Mar-2022 16:02
tug hunter   13-Mar-2022 11:59
How to start form a cold ship? cant find anything of a emergency generator and main switchboard. Cant even use pumps/pumpcontroles when i switch it on it wont hold.
Echologic1 ®   15-Mar-2022 01:09
tug hunter,
i made a new post with instruction manual.
Please, dont forget that this is not about starting/ operating internal alternative combustion engines.
This is a steam plant simulator. You start DG on start button, power SWB and proceed to steam plant.
Attachments ManualSimuladorVapor_removed.pdf (1 MB, Downloaded: 256 times)
tug hunter   06-May-2022 22:10
83981tug hunter,
Thanks for helping me out many thanks :D
Kind regards
tug hunter   06-May-2022 23:00
83981tug hunter,
I try a view times open valve of GO maby you can make a short video, i can't also no starting pumps for freshwater to the DG when i push starts start running and drop in RPM to 0 cant get any time to put the breaker on dthe MSB cant even start any pumps manualy.
kind regards
tug hunter   06-May-2022 23:36
Is there also someone how has de M11MAK IV? or MAK M11 IV version of Kongsberg?? engineroomsimulator?
Echologic1 ®   22-Jun-2022 13:26
tug hunter, I can´t make a video right now, because ive been busy, im sorry for that.
Anyway, you just need to power up your main bus bar. After that, you just start preparing installation: filling up deaerator with water, filling and lighting up boiler, produsing steam and so on. To fill up at first, you have to operate electrically driven pumps. And only after you start producing steam, turbine pumps can be operated.
Good luck!
cipherexist   27-Dec-2022 06:24
Can't run the simulator. its always stays on freeze even i already press F1 to run.. there is also a notification that simulator is running. but its stays on freeze
nikikito   04-May-2023 22:51
Hi everyone, Please let me know if this version is compatible with Windows 11.
geeor   14-Jan-2024 21:39
Good day, may i have some seed for the download please?
Thank you.
SDrabbit22   28-Feb-2024 23:58
Echologic1, The solution you ofered let us open the simulator but we can not start it, there are no initial conditions everything is empty or zero, how can we solve that?
leon.supmaritime   15-Mar-2024 17:22
once instaled, when you open the software (sp dual fuel), he drives you to an ip adress. My question is, how to instal correctly this software and open it correctly to work with ?
mythbuster   03-Dec-2024 00:55
Hello, everyone .
Please help me to launch program Windows 10
I cannot start simulator due to next message
"Can`t establish connection with License server(time out) Server adress was:127.0.0.1"
And after next window comes to fill license code
Also during installation came error that some file missing but I skip it. (Help.inx or whatever)
Thank You in advance
frankieg   14-Feb-2025 08:01
I am trying to setup the program but when I run the setup and click through the prompts It gives me an error "verify that the program exists and that you can access it". does anyone know how to fix this?
frankieg   14-Feb-2025 09:05
Does the Cracked file still work? it doesnt let me get past the license code after i replace the file in the bin.
Mateusz2940   16-Aug-2025 23:32
im unable to start diesel generators i checked DO valves and they were opened also for some reason i cant get turbo generators ready on electrical power plant page
Introduction to Marine Engineering (Second Edition) - D. A. Taylor [2003, PDF]
Marine Auxiliary Machinery 7th-edition - McGeorge H. D. [1995, PDF]
Kongsberg SP Dual Fuel Simulator v.2.4.0.0259 Instructions Manual- Kongsberg [2009]
Diesel Engines II - Kees Kuiken [2008, PDF]
MAN B&W 50-108ME/ME-C / Part I - Operation Manual [2006, PDF]
Guide to ship repair estimates (IN MAN-HOURS) - Don Butler [2000, PDF]
Germanischer Lloyd Rules ND and Programms 14.0 [2012 Edition]
The time now is: Today 09:02
