Bulldozer ®   05-Mar-2015 18:31
Kongsberg Norcontrol Neptune Simulator - MC90-V
Version: 2.3.0.0130
Developer: Kongsberg
Platform: PC (Windows)
Crack: Included
Description: The ERS-L11 MAN B&W 5L90MC–VLCC simulates a very large crude carrier with a MAN B&W slow speed turbo charged diesel engine as propulsion unit modelled with fixed and controllable propeller.
The model is based on real engine data that make the dynamic behaviour of the simulator close to real engine response.
The electrical plant includes two diesel generators, one turbo generator, one shaft generator/motor, and one 180 kW emergency generator.
The steam plant includes a D-type steam boiler, exhaust boiler, four cargo turbines, ballast turbine and condensing and feed water systems.
Control room operator station and panels and bridge and steering panels are included. If you are from Australia, visit this page for some suggestions
Additional info: Mount image in virtual drive.Follow the instructions in the Read me file.
The following dynamic models and features are included:
• Sea & LT/HT fresh water systems
Incl. FW generator
• Electrical power plant
Incl. diesel-, shaft- generator and turbo generators
• Start & service air compressors
Incl. compressor intermediate coolers &
emergency compressor
• Electrical power and pump management
Manual and automatic
• Battery charging system
• Steam plant
Incl. D-type oil fired boiler and exhaust boiler
• Diesel/heavy fuel oil systems
Incl. tanks, separators, viscosimeters
• Lubricating oil systems
Incl. separator
• Stern tube systems
• Propeller servo LO system
• CPP bow thruster
• Steering gear/autopilot
Incl. double acting IMO type steering gear
& ship course control
• Turbo charger systems
• Main engine control system
Incl. bridge, ECR and local control
• Main engine control air system
• FO high pressure system
Incl. VIT system,
• Cylinder indication diagrams
• Piston ring monitoring
• Main Engine Load Diagram
• Main Engine bearing system
• Air ventilation system
• Bilge wells & bilge separator
• Air conditioning plant
• Sewage treatment plant
• Incinerator plant
• Ballast system
• Refrigeration system
• Ship loading system
• CO2 scavenging air box fire extinguish system
• Remote CO2 release, emergency stops
& quick release valves
• Emission Control System (water emulsification &
Pmax-reduction/ SCR/ Scrubbing)
Keyboard Function Keys
F1 Run simulation
F2 Freeze simulation
F3 Exit the simulator
F4 Make Snapshot
F4+shift Snapshot Directory
F5 Operating Condition
F6 Scenario
F6+shift Init Condition
F7 Recall Picture
F7+shift Mark Picture
F8 Alarm Log Summary Display
F8+shift Page Acknowledge
F9 Malfunction List
F10 Variable List
F11 Alarm List
F12 Alarm Silence
F12+Alt Toggle window decorations
Home Directory
Home+shift Select Picture
Page Up Previous picture
Page Down Next picture
Ctrl + P Print hardcopy to default printer
Ctrl + L Display Message Log
K MC90V Simulator
Download [14 KB]
firco   08-Mar-2015 20:54
I couldn't get it work, when i tried to replace the simulator.exe with other simulator.exe it gave me error "Missing argument: -p <plant path>
20
ncl1951   09-Mar-2015 09:03
Hi replaced simulator.exe from daemon to Neptune BIN during .
During the installation do I have to select Custom????? If yes do I have to install all files or only the software???
In my case the result is :
The program open but only the but only the mimics :
F1 start does not work it remain in F2 freeze ,
No possibility to have any volume
Many thanks for any help.
PS Do I have to stop the antivirus??????
4
Bulldozer ®   09-Mar-2015 11:15
10689During the installation do I have to select Custom????? If yes do I have to install all files or only the software???
select CUSTOM and select all the packages to install
Up to you
I also have no any sounds
Load INITIAL CONDITIONS before setting RUN mode
ncl1951   09-Mar-2015 20:33
First of all many many thanks I finally got it and is working fine even if as engineer i miss a lot the sound.I had to find another way that may help :
1 Download the simulator in this page only to get the crack file
2 Downloaded and installed MC90-V v.2.5.1 [2013]
3 Copied the crack in Neptune Bin
It works fine and there are a lot a features like AC deck machineries etc.
Now the next step would be to have the sound does anyone know which ones are the files??? Not sound or wave of MC90IV probably we could copy them and replace the ones in MC90V.
Thanks again TTo Bulldozer for the help
3
Bulldozer ®   09-Mar-2015 21:56
10698PS from the program I can only open the funnel pictures is it correct???
what do you mean?
adita   09-Mar-2015 22:24
10699
what do you mean?
I mean that in Panel directory of the simulator I have
430 Ship Funnel CCTV
If i select it appers the funnel in operation,in the simulator there are other woking images but they can be opened only from the directory:
Neptune-Bin-VR-Engine Room-Unity version
adita   09-Mar-2015 22:28
quote....Whit this i can't get the virtual machine to work, but i now have a few extras that i didn't get on MC90-IV like
-air conditioning plant
-sewage treatment plant
- FW hydrophore
-HTFW on DG1 and DG2
-winches
-fire protection panel whit water mist system
And other minor changes in the diagrams (for example Emergency Air generator as an air refrigeration system and a manual pump).
Trying to play the virtual engine room, you will get an error but nothing else, the simulator still runs.end quote... this is the version I got
drcot   09-Mar-2015 22:30
I cant make it work. I installed the app. and now the problem is the freeze mode. How I cant activate initial conditions?
Thank you
kiage   10-Mar-2015 00:47
10702I cant make it work. I installed the app. and now the problem is the freeze mode. How I cant activate initial conditions?
Thank you
Press F5 To open the menu of simulator
masd   10-Mar-2015 01:47
10701quote....Whit this i can't get the virtual machine to work, but i now have a few extras that i didn't get on MC90-IV like
- FW hydrophore
-winches
You are talking about the 2.5 version of the kongsberg simulator, this one is the 2.3.
The 2.5 it's not cracked, but it's possible to run it. This one is cracked. I haven't tested this version yet, so perhaps you can start the virtual room from the simulator himself, on the 2.5 at this moment you can't do it.
Bulldozer ®   10-Mar-2015 11:02
I have no this item
Honestly , I don't use this simulator. I have enough practice with real equipment.)
Wisniowy   10-Mar-2015 18:59
I have no idea what are you doing wrong guys, on my PC is working well without problems.
I've made everything according to this instruction in notepad - on win7 everything is ok.
adita   11-Mar-2015 09:15
Including the Virtual Room?????
adita   11-Mar-2015 09:57
Both versions works fine I use 2.5 necause more complete
adita   11-Mar-2015 10:03
Both works fine I am using 2.5 because more complete,now it wolud be nice to find a medium 4 stroke ....
Bulldozer ®   11-Mar-2015 10:05
If you have questions, make it as clear as possible, preferable with screenshots
Norcontrol Neptune Desktop Simulator - MC90-IV v.1.2
Crude oil tanker "British Kestrel" Machinery operating manual - Worldwide Marine…
Medium Speed Engine Simulator v.2.2.0.44 [2001]
Unitest Marine Training Software (UMTS) v.2.0 [1997]
Operator’s Manual for Engine Room Simulator ERS L11 5L90MC VLCC (Version MC90-V) - Kongsberg [2009,…
DMSCTS setup - Marine Simulation Training Platform High-tech Ship Electromechanical Virtual…
The time now is: Today 15:53
