seacaptain ®   10-Nov-2021 15:11
MECHANICAL MEASUREMENTS
Year: 2015
Author: S.P.VENKATESHAN
Genre: Technical book
Publisher: JOHN WILEY
Edition: II
Pages count: 552
Description: This Book introduces measurement errors and methods of describing them so that measured data is interpreted properly. Statistical principles
involved in error analysis are discussed in sufficient detail. Concepts such as precision and accuracy are clearly explained. Different statistics useful in experimental studies,.Measurements of Temperature, Heat Flux and Heat Transfer Coefficient,Heat flux and Heat Transfer Coefficient,Measurement of Pressure, Fluid velocity, Volume flow rate, Stagnation and Bulk mean temperatures,Force/Acceleration, torque and power,Data Manipulation and Examples from laboratory practice.
(Ane_Athena Books) S. P. Venkateshan - Mechanical measurements 2nd edition-Wiley (2015).pdf
1A Unit Converter pro v.2.0.3 - Alexander Vollmar [2018] [Android]
Numerical Ship Hydrodynamics: An Assessment of the Tokyo 2015 Workshop (Lecture Notes in Applied…
Numerical Ship Hydrodynamics - An assessment of the Gothenburg 2010 Workshop - Lars Larsson,…
Automotive Mechatronics: Automotive Networking · Driving Stability Systems · Electronics - Prof.…
Inertial Navigation Systems with Geodetic Applications - Christopher Jekeli [2023, PDF]
Uncertainty Analysis of Methods Used to Measure Ship Fuel Oil Consumption - J. Travis Hunsucker,…
Pipe Flow: A Practical and Comprehensive Guide - Donald Rennels [2012, PDF]
On Structural Design of High-Speed Craft - Razolf M. [2013, PDF]
A High-Rate Virtual Instrument of Marine Vehicle Motions for Underwater Navigation and Ocean Remote…
Field Methods in Marine Science - SCOTT P. MILROY [2016, PDF]
The time now is: Today 14:19
