vitbar192 ®   22-Jun-2021 09:43
On Structural Design of High-Speed Craft
Year: 2013
Author: Razolf M.
Genre: Technical book
Publisher: KTH Royal Institute of Technology
ISBN: 978-91-7501-650-4
Pages count: 44
Description: The development in structural design and construction of high-speed craft has been extensive during the last decades. Environmental and economical issues have increased the need to develop more optimized structures, using new material concepts, to reduce weight and increase performance efficiency. However, both lack of, and limitations in design methodology, makes this a difficult task.
In this thesis a methodological framework which enables detailed studies of the slamming loads and associated responses for high-speed planing craft in irregular waves is established. The slamming loads can either be formulated based on numerical simulations, or on experimental measurements and pressure distribution reconstruction. Structure responses are derived in the time-domain using finite element analysis. Statistical methods are used to determine design loads and lifetime extreme responses.
The framework is applied to perform phenomenological studies of the slamming loading conditions for high-speed craft, and used to highlight and quantify the limitations in the prevailing semi-empirical method for design load determination with respect to slamming. A number of clarifications regarding the original derivation and the applicability of the prevailing semi-empirical method are presented. Finally, several potential improvements to the method are presented and the associated implications discussed.
Razolf M. Design of High-Speed Craft, 2013.pdf
Download [14 KB]
Hybrit Propulsion Systems - Bas Kwasieckyj [2013, PDF]
Design of a free-rotating wing sail for an autonomous sailboat - Tretow C. [2017, PDF]
Research on Ship Design and Optimization Based on Simulation-Based Design (SBD) Technique - Bao-Ji Z...
High Speed Catamarans and Multihulls: Technology, Performance, and Applications - Liang Y., Bliault ...
Practical Design of Ships and Other Floating Structures - Volume 1 - You-Sheng Wu, Guo-Jun Zhou, Wei...
The Centrifugal Pumps - Grundfos [2012, PDF]
Economiser energy control for increased service steam production - MAN Energy Solutions [2022, PDF]
Remote Controlled and Autonomous Ships in the Maritime Industry - DNV [2018, PDF]
Guidance and Control of Ocean Vehicles - Fossen T.I. [1994, PDF]
Air Lubricated and Air Cavity Ships: Development, Design, and Application - Pavlov G.A., Liang Y., B...
The time now is: Today 07:44
