vitbar192 ®   04-Jul-2020 08:52
Air Lubricated and Air Cavity Ships: Development, Design, and Application
Year: 2020
Author: Pavlov G.A., Liang Y., Bliault A., Shu-Long H.
Genre: Technical book
Publisher: Springer
ISBN: 1071604236
Pages count: 495
Description: Air Lubrication and Air Cavity Technology is a major development that has emerged in recent years as a means to reduce resistance and powering for many types of ships, and an efficient design for high speed marine vessels. This book introduces the mechanisms for boundary layer drag reduction and concepts studied in early research work. Air bubble and sheet lubrication for displacement vessels is outlined and the key projects introduced. Generation of low volume flow air cavities under the hull of displacement, semi displacement and planing vessels are introduced together with theoretical and empirical analysis and design methods. Resistance reduction, power reduction and fuel efficiency are covered for both displacement and high speed vessels. Air layer and air cavity effects on vessel static and dynamic stability are covered, linked to regulatory requirements such as IMO. Seaway motions and reduced impact load of high speed craft in waves are discussed including model test results. Integration of propulsion systems for optimum powering is summarized. A design proposal for a wave piercing air cavity craft is included in an appendix. A comprehensive listing of document resources and internet locations is provided for further research.
Pavlov G.A., Liang Y., Bliault A., Shu-Long H. Air Lubricated and Air Cavity Ships - Development, Design, and Applicationб 2020.pdf
Download [15 KB]
High Speed Catamarans and Multihulls: Technology, Performance, and Applications - Liang Y., Bliault ...
High Performance Marine Vessels - Liang Yun, Alan Bliault [2012, PDF]
High Speed Catamaran and Multihulls - Liang Yun - Alan Bliault - Huan Zong Rong [2018, PDF]
Guide for Air Lubrication System Installation - ABS [2018, PDF]
Advanced concepts of Bearing Technology [5th Edition] - Tedric A. Harris,Michael N. Kotzalas [2006, ...
Practical ship hydrodynamics - Volker Bertram [2000, PDF]
Design of Ship Hull Structures | A Practical Guide for Engineers - Yasuhisa Okumoto and Others [2026...
Next Generation Marine Wireless Communication Networks - Bin Lin • Jianli Duan • Mengqi Han • Lin X....
Guidelines for Direct Load Analysis and Strength Assessment - ClassNK [2024, PDF]
Theory And Design Of Air Cushion Craft - Yun L., Bliault A. [2000, PDF]
The time now is: Today 11:37
