skipper3362 ®   21-Jun-2021 18:01
Monopile Designer v21 update 1
Year: 2021
Version: 21.01.00.479)
Developer: Plaxis
64-bit OS compatibility: yes
System Requirements: windows 10 x64
Crack: Included
Description: Exploring current and future vessel designs in the offshore sector
PLAXIS Monopile Designer CONNECT Edition V21 Update 1 | 3.7 Gb
The PLAXIS development team is pleased to announce the availability of PLAXIS Monopile Designer CONNECT Edition V21 Update 1 is a software package intended for the design of monopiles asfoundation elements for offshore wind turbines under lateral loading conditions.
Calibration with target displacement at mudline in PLAXIS Monopile Designer
In previous versions, it was only possible to impose a prescribed displacement at the top of the pile, which required guessing before calculating how that would translate into the desired displacement at the mudline. This led to calculations either taking longer than needed or some trial-and-error to find the right value of the prescribed displacement. This parameter has been replaced by a target displacement at mudline, relative to the diameter of the monopile. PLAXIS Monopile Designer will automatically estimate the prescribed displacement imposed at the top and automatically stop the analysis when the calculation reaches the target point. This makes the Calibration process much more efficient and predictable. When further combined with the Subspace accelerator, now active by default, it can lead to significant speed improvement.
PLAXIS Monopile Designer (formerly PLAXIS MoDeTo) introduces an enhanced design method for monopile foundations. It transfers the results of the PISA Joint Industry Research Project to daily engineering practice. PLAXIS Monopile Designer enables dramatic reductions in the amount of steel of each monopile and, as such, in the overall costs of any wind farm. It can be used as a stand-alone tool for the rule-based design method and in connection with PLAXIS 3D for the numerical-based design method.
We are happy to announce that in April 2021 we released all-new PLAXIS versions: CONNECT Edition V21 Update 1. This includes PLAXIS 2D, PLAXIS 3D, PLAXIS 2D LE, PLAXIS 3D LE, PLAXIS Designer, and PLAXIS Monopile Designer.
CONNECT Edition V21 Update 1 adds functionality to improve productivity by improving the numerical process for non-linear systems using the new subspace accelerator, and we can use a new API to automate Limit Equilibrium slope stability analyses. On top of that, we made running analyses for offshore analysis of suction buckets easier using the new PLAXIS-SACS Suction Bucket Analysis tool.
By consolidating the product lines for geotechnical analysis since Version 21, we can now make big steps in interoperability between the Finite Element solution and the Limit Equilibrium solutions. The new consolidated PLAXIS product line also offers great new functionality with new constitutive soil models, e.g., NorSand, PM4Silt, and a new way to deal with unsaturated soil strength. We invested in improvements on tunnel CAD import. And we added a calculation convergence log to better understand the numerical process.
Bentley Systems is a software development company that supports the professional needs of those responsible for creating and managing the world’s infrastructure.
Product: PLAXIS Monopile Designer
Version: CONNECT Edition V21 Update 1 (21.01.00.479) *
Supported Architectures: x64
Website Home Page : http://www.plaxis.com
PlaxisMonopileDesignerx64_21.01.00.479
Download [21 KB]
MoDeTo CONNECT Edition V20 Update 4 v.20.04.00.790 - PLAXIS Bentley [2020]
MOSES CONNECT Edition Version 12 v.12.04.00.78 - Bentley [2021]
SACS Connect v.23.00.00.322 - Bentley [2023]
Multiframe 2024 v.24.00.00.722 - Bentley [2024]
MOSES 2024 v.24.00.00.722 - Bentley [2024]
Offshore Wind Power: Reliability, availability and maintenance - Peter Tavner [2021, PDF]
ORC VPP Documentation - Collective [2009, PDF]
Offshore Pile Design - Pierre Tirant [1992, PDF]
ShipManager-88 v.4.0.3 (Loading/Unloading Program for 57000 DWT bulkcarrier) [2009]
Analysis of Regulatory Barriers to the use of Autonomous Ships - DMA [2017, PDF]
The time now is: Today 19:03
