skipper3362 ®   28-Dec-2021 17:22
MOSES CONNECT Edition Version 12
Year: 2021
Version: 12.04.00.78
Developer: Bentley
64-bit OS compatibility: yes
System Requirements: windows 10
Crack: Included
Description: The MOSES development team is pleased to announce the release of MOSES CONNECT Edition V12 Update 4 (12.04.00.78). This update contains a number of new features including tools that allow for interoperability with NREL’s FAST, an aeroelastic wind turbine solver.
MOSES CONNECT Edition Version 12 Update 4 - New Features
- A technology preview of the export of wave elevation at the global origin from the &ENV command ensuring identical wave environments are used in FAST and MOSES.
- A technology preview of the automated import of time history data generated by FAST via the FAST_TOOLS macros (OpenWindPower Floating Platform and Worksuite licenses only).
- A new sensor for detecting clashes of mooring lines in a time domain simulation.
- Simple tools for the import and merging of results tables in MOSES Executive to allow for easy data comparison.
- Upgrades to the CM2 meshing library in Modeler to improve speed and mesh quality.
- Precede, the SACS strucutural modeler, which is now available with every MOSES license.
- Load case selection and modification when exporting strucutural results to the Common Solution File for post-processing.
MOSES is integrated offshore simulation software. Minimize offshore project risks with designs optimized using MOSES integrated simulation software. Apply industry best practices for installation and design sequences, and explore design alternatives with the efficiency and flexibility of a unified modeling environment. Simulate complete system response with advanced, integrated solvers for hydrostatic, hydrodynamic, mooring, and structural behavior. Avoid rework and project delays by collaborating with structural teams using integration with SACS.MOSES helps you solve complex offshore engineering problems and produce accurate high-quality models and platform designs for future reuse.
Additional info: pach maker is includeed , but it can give a false positive in antivirus
MOSES CONNECT Edition V12.04
Download [20 KB]
MOSES 2024 v.24.00.00.722 - Bentley [2024]
MoDeTo CONNECT Edition V20 Update 4 v.20.04.00.790 - PLAXIS Bentley [2020]
Multiframe 2024 v.24.00.00.722 - Bentley [2024]
SACS Connect v.23.00.00.322 - Bentley [2023]
Monopile Designer v.21.01.00.479 - Plaxis [2021]
Sail Time -Track Sea Contracts v.1.8 - A.S.C [2025] [Android]
Mastering Import and Export Management - Thomas A. Cook [2017, PDF + EPUB]
Model Boats Volume 68 Number 816 - Martyn Chorlton, editor [2018, PDF]
Cadence FINE MARINE v.12.1 - Candence [2023]
Draft Survey and Trimming Assistant on Excel for Bulk Carriers and General Cargo Version v.2.3 - Med...
The time now is: Today 15:00
