NNT ®   15-Feb-2015 18:37
ShipManager-88 - Loading/Unloading Program for 57000 DWT bulkcarrier
Year: 2009
Version: 4.0.3
Developer: Techmarine Co., Ltd.
Windows7 compatibility: yes
Crack: Not needed
Description: Leading the trend of shipboard calculation, data processing, ship shore communication and vessel automation, Techmarine Co., Ltd., provides you with modern microprocessor-based loading computer, "SHIP MANAGER", which carries extremely powerful loading calculation and other software on standard general purpose computer.
The whole system was designed to be used by non-computer oriented user such as ship's officers and/or shore based cargo planners, and no specific knowledge about computer is required to run the system.
Additional info: Copy SM directory on your computer and run Shipmana.exe or sequence.exe (Loading/Unloading Sequence program above to see the sequence of cargo loading and discharging step by step.)
Major functions
This material explain the full aspects of "SHIP MANAGER" loading programs, the major functions of which are as follows :
1. Automatic calculation
2. Displacement & Deadweight Calculation.
3. Trim & Drafts (fore, mean, aft) calculation.
4. Draft (fore, aft and mean), correction due to difference of sea water density.
5. Heeling angle calculation.
6. Trim and heeling adjustment by using two pairs of fwd, and aft. Tanks
7. Propeller immersion calculation.
8. Shear force and bending moment at the prescribed frame points with visual.
9. Maximum values of bending moment and shear force with their actual position
10. Displacement and Deadweight calculation based on actual Drafts Physically measured on draft
marks.
11. Static stability (KMT, KG, GGo, GoM) Calculation.
12. Intact stability calculation including GoM according to IMO A.749(18)
13. Free surface moment (Maximum / Actual).
14. SWBM and SF in the hold flooded condition cargo hold acc. to IACS UR S17.
15. Grain Stability
16. Loading / Unloading Sequence according to IACS UR S1A
Initial stage setting
Can read from Loading condition file
Sequence Report
Each steps draft, Trim, GM check
Each steps shear force/bending moment check
Sequence diagram
A few screenshots
SM
Download [17 KB]
Guest   18-Mar-2016 20:47
what is the minimum system requirement of this?
kwek   19-Oct-2016 11:17
help please exeption EInOutError in module shipmana exe. appear! help please!! thanxx
kwek   20-Oct-2016 11:45
help please exeption EInOutError in module shipmana exe. appear! help please!! thanxx Тема закрыта Тема закрыта Тема закрыта
thecrow   27-Feb-2018 15:26
Same problem, program dont like to work-EInOutError in module shipmana exe. appear. Any idea???
jzoo   05-Dec-2018 05:47
i am hoping that there will be next update for the 100,000 and above grt vessels with 7-9 cargo holds.. thank you so much and more power
Ship Manager 88 v.4.52.2.14 - Loading program for 13000 DWT Oil/Chem Tanker - Techmarine Co. Ltd [20...
WinCASP ships profiles - CASP [2001]
Easeacon v.5.66 (BulkCarrier) - Marine Alignments A/S [2016]
CargoMax for Livestock Carriers Demo v.2.1 - Herbert-ABS [2020]
MACS3 Loading Computer System v.3 .NET [2013]
LoadCom - Loading program for 16000 DWT Oil/Chem Tanker v.1.5 - Shin Kurushima Dockyard Co., Ltd [20...
SHIPMANAGER-88 v.2-MAY-2019 (FSRU/LNGc Vessels) v.64-bit - TECHMARINE [2019]
MACS3 Training Course for Container Vessels v.1.1.29.84 - NAVIS [2020]
Loadstar v.1.0 - IBM [2008]
Ship’s Stability and Load Management Software Collection [Loadicators] - Various [201x-2020]
The time now is: Today 03:30
