letmein ®   07-Jun-2021 08:27
Practical Variable Speed Drives and Power Electronics
Year: 2003
Author: Malcolm Barnes
Genre: Technical book
Publisher: IDC Technology
Pages count: 299
Description: This book will benefit anyone associated with the use of VSDs in the industrial or automation environment. This book will also benefit those working in system design as well as site commissioning, maintenance and troubleshooting. Although a basic understanding of electrical engineering principles is essential, even those with a superficial knowledge of VSDs will substantially benefit from this book. In particular,
We would hope that you will learn the following from this book:
• The principles of AC variable speed drives for industrial speed control
• The essentials of squirrel cage induction motors
• The latest developments in power electronic converters used for VSDs
• How to select the correct AC variable speed drive for industrial applications
• How to identify faults on VSDs and how to rectify them
• The key issues about flux vector control and how it can be used in drive
applications
• The main concepts in interfacing the control circuits of VSDs with PLCs/DCSs
using serial data communications
Practical Variable Speed Drives and Power Electronics.pdf
Electrical and Electronics Engineering eBooks [PDF]
Foundation Course For Electrical Engineering Technician - 3G E-learning LLC [2021, PDF]
Fundamentals of Electric Machines - Warsame Hassan Ali /Samir Ibrahim Abood /Matthew N. O. Sadiku [2...
Understanding boat diesel engines - John C. Paine [2005, PDF]
Guidance Notes for Control of Harmonics in Electrical Power Systems - ABS [2006, PDF]
Gas Turbine Engineering Handbook - Boyce Meherwan P. [2012, PDF]
Ship Electro-Pneumatic & Hydraulic (Electrical Circuit of Shipboard Pneumatic & Hydraulic) - Arjay M...
Design of Rotating Electrical Machine - Juha Pyrh¨onen, Tapani JokinenHanna, Niemel¨a [2008, PDF]
Advanced Motor Control Systems In Oil & Gas Industry [2024, MP4]
Fundamentals Of Electric Motor Drives With Induction Motor [2023, MP4]
The time now is: Today 03:21
