Ferreirolo ®   15-Jun-2020 21:08
Guidance Notes for Control of Harmonics in Electrical Power Systems
Year: 2006
Author: ABS
Publisher: ABS
Pages count: 240
Description: Harmonics (or distortion in wave form) has always existed in electrical power systems. It is harmless as long as its level is not substantial. However, with the recent rapid advancement of power electronics technology, so-called nonlinear loads, such as variable frequency drives for motor power/speed control, are increasingly finding their way to shipboard or offshore applications. Harmonics induced by these nonlinear loads are a potential risk if they are not predicted and controlled.
The ABS Guidance Notes for Control of Harmonics in Electrical Power Systems has been developed in order to raise awareness among electrical system designers of the potential risks associated with the harmonics in electrical power systems onboard ships or offshore installations. These Guidance Notes encompass topics from the fundamental physics of harmonics to available means of mitigation to practical testing methods. These Guidance Notes are intended to aid designers to plan an appropriate means of harmonics mitigation early in the design stage of the electrical power distribution systems to make the system robust and predictable.
GUIDANCE_NOTES_ON.pdf
Download [4 KB]
Guide for Dynamic Positioning System - ABS [2021, PDF]
ABS - Guide for Dynamic Positioning Systems - ABS [2021, PDF]
VFD Challenges for Shipboard Electrical Power System Design - Mohammed M. Islam [2019, PDF]
Electrical and Electronics Engineering eBooks [PDF]
AC Electric Motors Control: Advanced Design Techniques and Applications - Fouad Giri [2013, PDF]
IEC 60092 - Electrical Installations in Ships - IEC [2016, PDF]
Design of Shipboard Power System Grounding / Earthing - Norbert Doerry ,Mohammed M. Islam, John…
Power electronics handbook - Muhammad Rashid [2011, PDF]
Electrical systems in pod propulsion - Lena Bergh Ulrika Helldén [2007, PDF]
Practical Variable Speed Drives and Power Electronics - Malcolm Barnes [2003, PDF]
The time now is: Today 16:25
