arun25hyd ®   04-Jan-2020 14:54
Design of Rotating Electrical Machine
Year: 2008
Author: Juha Pyrh¨onen, Tapani JokinenHanna, Niemel¨a
Genre: Technical book
Publisher: John Wiley & Sons, Ltd
Pages count: 541
Description: Electrical machines are almost entirely used in producing electricity, and there are very few
electricity-producing processes where rotating machines are not used. In such processes,
at least auxiliary motors are usually needed. In distributed energy systems, new machine
types play a considerable role: for instance, the era of permanent magnet machines has now
commenced.
About half of all electricity produced globally is used in electric motors, and the share of
accurately controlled motor drives applications is increasing. Electrical drives provide probably
the best control properties for a wide variety of processes. The torque of an electric motor
may be controlled accurately, and the efficiencies of the power electronic and electromechanical
conversion processes are high. What is most important is that a controlled electric motor
drive may save considerable amounts of energy. In the future, electric drives will probably
play an important role also in the traction of cars and working machines. Because of the
large energy flows, electric drives have a significant impact on the environment. If drives
are poorly designed or used inefficiently, we burden our environment in vain. Environmental
threats give electrical engineers a good reason for designing new and efficient electric
drives.
Finland has a strong tradition in electric motors and drives. Lappeenranta University of
Technology and Helsinki University of Technology have found it necessary to maintain and
expand the instruction given in electric machines. The objective of this book is to provide students
in electrical engineering with an adequate basic knowledge of rotating electric machines,
for an understanding of the operating principles of these machines as well as developing elementary
skills in machine design. However, due to the limitations of this material, it is not
possible to include all the information required in electric machine design in a single book,
yet this material may serve as a manual for a machine designer in the early stages of his or
her career. The bibliographies at the end of chapters are intended as sources of references
and recommended background reading. The Finnish tradition of electrical machine design is
emphasized in this textbook by the important co-authorship of Professor Tapani Jokinen, who
has spent decades in developing the Finnish machine design profession. An important view of
electrical machine design is provided by Professor Val´eria Hrabovcov´a from Slovak Republic,
which also has a strong industrial tradition.
Rotating Electric Machine
Download [4 KB]
Arcan   04-Jan-2020 18:32
arun25hyd, BTW rule 3.15 : It is not allowed to abuse the use of CONTINUOUS CAPITAL letters (Caps Lock).
Fix please.
virtual   05-Jan-2020 01:15
You could place the contents screen shots in the contents area rather than in the screenshots area and type the contents. Now You need to upload three screen shots from different parts of the book (I.e. beginning, mid and end ) in order to comply with the rules. Use the pencil on the top right hand corner to enter the edit status. There you can shift the syntax commands of the screenshots spoiler to the contents spoiler and to upload New images for the screenshots. Good luck.
Principles of Electric Machines and Power Electronics, 3rd Edition - P.C. SEN [2014, PDF]
Pipe Flow: A Practical and Comprehensive Guide - Donald Rennels [2012, PDF]
Electric Motors and Drives Fundamentals, Types and Applications - Austin Hughes and William Drury…
Electric Motors and Drives: Fundamentals, Types and Applications - Austin Hughes, Bill Drury [2019,…
Fundamentals of Electrical Machines - Ants Kallaste [2025, PDF]
Practical Variable Speed Drives and Power Electronics - Malcolm Barnes [2003, PDF]
Electrical Machine Rewinding - 3G E-learning LLC [2023, PDF]
Electrical Insulation for Rotating Machines 2004 - Greg C. Stone - Edward A. Boulter - Ian Culbert…
Shipboard Propulsion, Power Electronics, and Ocean Energy - Mukund R. Patel [2012, PDF]
Electric Drive Dimensioning and Tuning - Valery Vodovozov [2022, EPUB]
The time now is: Today 16:54
