twicer ®   28-Apr-2021 14:11
Advisory on Cold Expansion Technology
Year: 2020
Author: ABS
Pages count: 26
Description: Cyclic loading from ocean waves can cause fatigue damage and cracks in marine and offshore
structures. If these cracks are left to propagate they can compromise the structural integrity and safety of the
vessel/asset. To protect the vessel/asset and preserve life and the environment, class societies typically require
owners to permanently repair cracks located at critical areas of structures. For cracks located at non-critical areas,
when constraints such as hot work restrictions make permanent repairs impractical during normal operations,
temporary repairs may be considered on a case-by-case basis.
To permanently repair a cracked structure inside the cargo tank of a Floating Production Storage and
Offloading (FPSO), the operator must:
• Halt production
• Empty the affected tank
• Clean the affected tank
• Make the confined space safe for human entry
• Make the confined space safe for hot work (depending on the type of repair)
In today’s sensitive economic environment, owners want a repair solution that features an expedited,
reliable, and safe repair process. A temporary repair method with these features is desired to allow normal
operations until the next scheduled inspection. Cold expanded crack arrest hole technology has been
used to improve the fatigue life of crack arrest holes (i.e. stop holes) and satisfies the necessary features
of repair (Reid 2014).
Cold_Expansion_Technology_Advisory ABS.pdf
Download [972 B]
Personal Protective Equipment - Use of PPE DVD#2526 (Seagull Maritime Training Films) [2017, DVD]
Guidance Notes on Composite Repairs of Steel Structures and Piping - ABS [2021, PDF]
IICL: General Guide for Refrigerate Container Inspection and Repair, 4th Edition - IICL [2016, PDF]
Bulk Carriers – Guidelines for Surveys, Assessment and Repair of Hull Structures - IACS [2007, PDF]
Underwater Inspection and Repair for Offshore Structures - John V. Sharp & Gerhard Ersdal [2021, PDF...
Guidance Notes on Maintenance and Repair of Protective Coatings - ABS [2017, PDF]
Sea loads on ships and offshore structures - O.M. Faltinsen [1999, PDF]
Double Hull Oil Tankers - Guidelines for Surveys, Assessment and Repair of Hull Structures - IACS [2...
IICL: Guide for Flatrack Container Inspection - IICL [2003, PDF]
IACS Bulk Carriers - Guidelines for Survey, Assessment and Repair of Hull Structures - IACS [2017, P...
The time now is: Today 05:18
